Sonblack
PDAVIET WM6.5 ROM - I8000
CE OS 5.2.23569 BUILD 23569.5.5.0 PV
JMLToday contable skin/mod phiên bản 2.11 đã được cook vào ROM. Đây là phiên bản được thiết kế độc quyền cho loạt ROM của Sonblack bởi contable từ Modaco. Vấn đề đồng hồ hiển thị không đúng đã được fix, cải thiện quá trình cài đặt ban đầu và tiết kiệm nhiều bộ nhớ cho ROM
Release version of JMLToday contable skin/mod V2.11 added. This version is exclusively designed for SB Rom Series. "Clock distortion" fixed, improved initial installing procedure and save more memory.
Lời cám ơn - Special thanks to:
Wes58 for his tool as my requirements (always the best support for me)
contable (Modaco) for his skin/mod of JMLToday version 2.11, his opinions about this, his more donations and all what he did for I8000 community and me...
Admin Kawaguchi (for his tools), Manager PhamQuang (so much), Super Mod Batkid (so much), Adv Mod NhatToai, Adv Mod TranMinhMan, S Vip Tom_codon (all of them are from PDAVIET)
Member huyentrangallery (from Samsung Mobile Vietnam, supported I8000 device for cooking)
JHML (Xda-Developers) for his application, JMLToday
Lechux (Xda-Developers) for his icons set I used
Gary Crutcher (Modaco) for his chicks wallpaper section.
Lancez (Modaco) for his opinions which I need to know and his big donation
tacchan23 (Modaco) for Taskbar Icons, theme.
sorg (Modaco) for modded file "Camera.exe" for I8000 which I cooked in the rom (SB22, SB24).
Henrie, koperko, wkmmx500, Ah Huat Low, fattmatt, Macarov Gelu, Monyozt from Modaco for their donations
Thông tin ROM - ROM Informations:
Basic ROM: XXJD6
ROM Date: 09 May, 2010
Language: only WWE
Pagepool: 12MB
Chuẩn nén LZX được sử dụng
LZX compress standard is used
Version: I8K23569JD6SB24
Hỗ trợ hiển thị phông chữ tiếng Hoa.
Chinese fonts are available in the ROM
Lưu ý: Trong trường hợp có vấn đề kết nối, vui lòng sử dụng Restore Connection trong Samsung Settings
Note: In case of data connection problems, please Restore Connections in Samsung Settings
Hình minh họa - Illustrative images:
Chức năng chính - Main functions:
- Core 5.2.23569 Build 23569.5.5.0
- JMLToday contable OMNIA II mod/skin version 2.11, hỗ trợ màn hình ngang (cám ơn sự hỗ trợ của contable)
Lưu ý: Có thể thay đổi Predefined SMS bằng cách sửa file PDSMS.txt trong thư mục Program Files\JMLToday
JMLToday contable OMNIA II mod/skin version 2.11, supported landscape mode (thanks so much contable for his support)
Note: Predefined SMS can be changed in PDSMS.txt located in Program Files\JMLToday folder
- JMLToday sẽ tự động cài đặt ở lần khởi động đầu tiên, các bạn chỉ việc chọn nơi bạn đang ở (một vài nơi là không có sẵn)!
JMLToday will be installed automatically in first boot, you only choose your location (some locations are not available)!
- .NET Compact Framework Version 3.5.9198.00
- Office Mobile 2010 (Word Mobile, Excel Mobile, PowerPoint Mobile, OneNote Mobile, SharePoint Mobile)
- Samsung Keyboard - JD3
- Samsung Dialer Skin - JD3
- Power Calculator - JD3
- ING Change Font version 1.08 (thank Luigi.ING, www.mobilehtc.net)
- MMTaskManager v1.8.100421 (thank vn1minh from htcpedia.com, for details please visit http://htcpedia.com/forum/showthread.php?t=2357)
- Orientation Detection v1.0.3584.9343 for Omnia II
- MSN Money
- MSN Weather
- Marketplace
- SRS WOW HD for OMNIA II
- FlashLight
- Tacchan23_WhiteBlack_6.5.x_VGA_v7 theme (thank again tacchan23)
- VnKeyb v2.2.0 by ntd (Skin from hanoiwap, included Set Keyboard in English - Thanks Super Mod Tmap)
- Check New ROM by Admin Kawaguchi
- Java_JblendPackage_2_1_2_1_20090429_2_1_R6 from Topaz II
- AdobePDF_2_5_1_0_404840_03
- CHome Editor v1.6beta (thanks Showaco)
- S2U2 v2.40 (thanks A_C)
- Soft Reset (by Sonblack)
- Các ứng dụng cơ bản cho PPC với các phiên bản mới nhất gồm:
Basic applications for PPC with its latest version as follow
CleanRAM (v2.2), ClearTemp (v1.3), Total Commander (v2.52 beta 2),PIM Backup (v2.8), Synchro Time (v0.95), Advanced Configuration Tools (v3.3)
- Loại bỏ các ứng dụng không cần thiết mà tôi không thích (xem danh sách)
Removed more unnecessary utilities which I don't like! (see the list)
Asphalt4 (Game), Crayon Physics (Game), Dice (Game), Face Book, Podcast, QIK, RSS Reader, Cube, MainMenu, OnlineWidget, Samsung Today, Video Editor, Digital Frame, Smart Search, Unit Converter, Video Editor, Application Store, Communities (Share Pix), Connected Home, Midomi, Task Switcher, SPlugin Favorites, Google Maps, Smart Memo, Smart Reader, Smart Sync, Youtube, My Files, Adobe Reader, Java,...
Ai không thích icon nhỏ trong Start Menu có thể xóa toàn bộ registry bên dưới và reset lại máy.
Anybody don't like small icons of Start Menu can do as follows in order to delete all following Registry and Reset
[HKEY_LOCAL_MACHINE\Security\Shell\StartMenu]
"CustomGridForm"="StartMenu_Sonblack"
Hình nền của JMLToday - Wallpapers for JMLToday: Download here
Hoặc có thể tự làm bằng cách tham khảo - Or you can make it yourself by clicking here: JML WALLPAPER FRAMEWORK AND HOW TO (page #1, post #6)
Chọn một hình nền, thay đổi tên thành Bkg.png và chép vào thư mục JML đối với các phiên bản JMLToday contable skin/mod V2.0 và 2.1
Select one wallpaper, change name to Bkg.png and copy it to folder "JML" with JMLToday contable skin/mod V2.0 & 2.1
Cũng làm như trên nhưng chép vào thư mục Program Files\JMLToday\skins\default\sys đối với các phiên bản cũ hơn.
Select one wallpaper, change name to Bkg.png and copy it to folder "Program Files\JMLToday\skins\default\sys" with old versions of JMLToday contable skin/mod.
For JMLToday: please see details at JMLToday contable skin/mod V2.0
For Wallpapers: you can choose: General Wallpapers and JML Wallpapers
For Chinese fonts: please see details at Chinese fonts are selected by Lancez
Vui lòng up rom bằng phiên bản Octans Downloader mới nhất. Phiên bản mới nhất là 2.14
Please flash the ROM by latest Octans Downloader version. Its latest version is 2.14
Tải ROM - Download links:
Không cần pass giải nén
No need password for uncompressing
Chúc vui!
Enjoy it!
Sonblack
