[13/10/2012] Sabsa Prime v7.0 | 4.0.3 | Sense 4 | Fully Working |
mrtuaans
image.php
Note
Android Version: 4.0.3 (IceCream Sandwich)
Based on: Incredible S 2.22.405.1
Sense Version: 4.0A
Supported Devices: Desire HD / Inspire 4G
v7.0:
- Added Ril_Switch.so
- Fixed Location app
- Reanme To Desire HD With Beats Audio
- Fixed LockScreen Pin
- Improved Battery Life
- Improved Performance
- Add More Region & Languages
- Fixed Inspire 4G Patch
- Improved Synced Contact Picture Quality
- Something More That I Can't Remembered
LINK DOWNLOAD
MD5: bbd6ee368b5cceeb58139d1942a21ea3
v5.0: http://d-h.st/gSs
- Fixed Camera ( Fully Working )
- Updated Kernel To beastmod 1.5
- New ext.jar
- Gallery From One X
- Music From One X
- Added Streak Live Wallpaper
- Fixed Fallout Tweaks
- Added Sense 4 Recent Apps
- Added Sense 4 Dialer
- Added Sense 4 People
- Added Arabic/Persian Keyboard
- Fixed AutoBrightness
- Improved Smoothness
- Improved Batterylife
- Update Aroma Installer Options
v4.1 Download v4.1 OTA: http://forum.xda-developers.com/showpost.php?p=31118813&postcount=949
- LockScrren back to sense 4A
- Camera Fixed ( Still need Flash on )
v4.0: http://d-h.st/LTn
Mirror
http://filebulk.com/vrk7pa6nbu11/Sabsa_Prime_v4.0_By_AlirezaB.zip.html
- Removed Files That didn't have permission
- Camera Ported From One S
- Added Weather Video ( ported From Ville C2 )
- Added Sense 4 Lock screen
- Added Galaxy Live Wallpaper
- Disable Boot Sound
- New Bootanimation
- New Downanimation
- Added init.d Tweaks
- Updated Google Play Store
- Improved I/o
- New Aroma Installer Options
- New Method for % Battery
- Something More That I Cant Remmembred
- Big Thanks To nitsuj17 ( he's Very kind )
v3.0: http://api.viglink.com/api/click?fo...ownload v3.0&jsonp=vglnk_jsonp_13456839830202
- Added Full Beats Profile
- Added Full Equlizer
- Fixed Camera ( Fully Working ) Tnx To jeremyboo
- Fixed Build.prob ( Show Desire HD Now )
- Removed Google Books & Videos
- Added Options In Aroma Installer
- Aroma New Options
Support Full Languages With More Locale App
HTC Keyboard With Arrow
- Changed Google Play Store
- Fixed Facebook & Twitter
- Fixed Freindstream ( Show Facebook Account Now )
- Activated HW acceleration on Calendar app
- Activated HW acceleration on Weather app
v2.1: http://www.uploadbaz.com/yxwcp8shc2tf
0r https://hotfile.com/dl/168119125/bbd5b00/Sabsa_Prime_v2.1_OTA.zip.html
- Fixed Bluetoothd.so
- Added Facebook Engine That was missed in v2.0
- Added Twitter Engine That was missed in v2.0
- Added Cube Animation ( Like One X )
- Added Sense 4 World Clock
Đây là bản update bổ sung cho v2.0
Bạn tải file đó về rồi copy vào sdcard, đổi tên file thành update.zip.
Vào lại Recovery, chọn 'apply update from sdcard', nó sẽ tự động update lên v2.1
Tks to boysleep
update 20.08.2012:
http://api.viglink.com/api/click?fo...0</b></font>&jsonp=vglnk_jsonp_13452630654063
v2.0
- Added Aroma Installer
- Fully Fixed Camera
- Fixed Usb Mount
- Added Inspire 4G Patches (Need To Test)
- Added 10 Skins
- Added Fallout Tweaks
- Added Advance Power Menu
- Added Extended Quick Settings
- Added Menu On Home Screen
- Added Live Wallpapers
- Fixed Mic In Phone Call
- Added HTC Note
- Removed Mirror App
- Fixed Smiles
- Updated Es File Explorer To 1.6.8.1
- Updated Google Maps To 6.10.0
- Updated Google Plus To 3.1.1
- Updated Gmail To 4.1.2
- Updated Facebook To 1.9.7
- Updated Adobe Reader
- Updated Adobe Flash Player
- Added More Widget Thats Missed In Sense 4A
- Removed Unneeded Apps
- Auto Zipalign On Boot
- Added Battery Calibration Tweaks
- Increase SD Card Speed
- Added Twitter
- Added Freindstream
- Added Sound Image From Virtous Infinity
- Rewrite Build.prob
Code:
v1.0
- Based On Lastest Pirmo RUU 2.22.401.1 release-keys
- HTC Sense 4.0A
- BeastMode Kernel ( Thanks To Blackout Team )
- Deodexed
- Rooted
- Added Busybox
- Fully Zipalign
- Init.d Tweaks Support
- Added Build.prob Tweaks
- Fixed Wifi
- Fixed Camera ( camrecorder worked )
- Added Es File Explorer
- Added Bravia Engine
- And Something more that i cant remembered
You Tell Me
Download v1.0: http://persianfarsh.s113.rapidbaz.c...us./32885458?Sabsa_Prime_v1.0_By_AlirezaB.zip
MD5 Sum: 2321A31E5013E360B27B44E8805F2A26
- HTC Desire HD
- S-Off or Unlock Bootloader
- CWM Recovery or 4EXT Recovery
- Download The Rom
-Put Rom in Your SD Card
-Do Full Wipe
- Flash The Rom
-Reboot
Virtous Team
Blackout Team
Football
nguồn: http://forum.xda-developers.com/showthread.php?t=1839004
doyen2001
bản này mình đang theo dõi bên XDA, thấy có người dùng thì ok, có người dùng thì lỗi lắm, nói chung đợi ra bản chuẩn rồi up thử xem.
boysleep
không phải bạn ơi, đây là bản update bổ sung cho v2.0
ctheanh
anh em xem the nao cho cai link mediafire di chu load the nay khong the nao ma cho doi duoc
mrtuaans
đã update 2.1. V2.0 bật wifi nên hay bị giật, call thì đôi lúc bị đơ, Pin thì ok
chrjtm
Sao mình cài room này vào máy chạy rất chậm nhỉ? Trước khi up room này mình cũng đã wipe full rồi mà không hiểu sao chậm kinh khủng
boysleep
mình đã up lên v2.1, mọi chức năng đều ok và ổn định(chưa test game hd)
bạn thử full wipe/factory reset rồi cài lại xem.
ROM này vẫn còn beta nên có thể chưa ổn định với 1 số máy.
mrtuaans
dùng 1 thời gian mới thấy bạn ah, chứ mới đầu dùng thì mọi thứ ok hết . Đang beta nên dow về up thử rồi chia sẻ kinh nghiệm cho a e thôi ^^
mrtuaans
up date V3.0 (23/08/2012)
v3.0
- Aroma New Options
