dinhtuandung2012
- Based on VILLEC2 3.19.401.101
- Android 4.1.1 with Sense UI 4+
- SebastianFM Kernel
- Multi-language (WWE)
- Deodexed & Zipaligned using SDK r21.0.1
- Memory optimizations
- Init.d scripts support
- Ramdisk tweaks
- Option to remove apps (AROMA installer)
- OTA Updates
- Venom APPS: Tweaks, Eqalizer, SidePanel, HUB, Package and App installers, downloads UI, SuperUser, Beats Notificaton and more
- All apps updated to the latest version available
Status Bar
Rosie
Lockscreen
Buttons
Misc
Advanced
Other improvements
- Vertical QuickSettings style
- QuickLauncher n Horizontal QuickSettings style
- Hide n Reorder QuickSettings
- Hide icons
- Customize icons
- Customize status bar and notification area clock/date
- Customize battery(MIUI/Text/Colors etc)
- Status bar and notification area operator icons
- Customize transparency level
- CM Brightness control
- Changeable carrier text
- Changeable background color/image
- Block on lockscreen
- Custom apps on tab header and settings icon
- Information line
- Weather in notification area
- Shake and volume keys actions
Rosie
- Changeable background color/image for appdrawer(with transparency support)
- On/Off wallpaper scrolling
- On/Off infinite scrolling
- On/Off landscape support
- Hide navbar background
- Hide labels from workspace
- Icon packs support
- Extended appdrawer
Lockscreen
- Optional AOSP lockscreen
- Hide carrier text/date/time
- Customize shortcuts
- Customize app notifications
- Slide2Unlock
- Sweep2Wake (For supported kernels only)
- Buttons to unlock
- Music control with volume buttons
- Customize long press home button
Buttons
- Customize 3-Finger gesture
- Customize capacitive buttons backlight
- Use volume up to wake the device
- Use volume down to shut screen off
- Customize long press back/home/recent buttons
Misc
- Access hidden phone menu
- Enable cube animation
- Customize transition animations
- Customize overscroll glow color
- Customize auto backlight brightness
- Customize minfree values
- Customize power menu items
- Enable/Disable PC Tool CD
- Enable/Disable SMS screen on
- Enable/Disable fast dormancy
- Enable/Disable HTC SmartSync
- Enable/Disable volume sound
- Customize NFC restrictions
- Sony xLoud enhancement
- Sony BRAVIA engine
- Customize navigation app in HTC car
Advanced
- Fix permissions
- Zipalign apks
- Mount system rw/ro
- Disable logcat
- Wipe cache/dalvik
- Customize font
- Customize boot/down animation
- Customize boot sound
Other improvements
- More when 10 eqs preset + custom equalizer
- Extended Venom Beats notification
- SOS and Auto flash options added to flashlight app
- Added Rosie menu support
- Unlimited tabs in browser
- Extended Powersaver - more powersaving options - On/Off notification - Change auto on battery level
- Highly improved Camera with many options - thanks lypota for original mod
- Added two new transparent clock widgets
- Custom downloads UI
- Custom package installer
- Our whole team, all awesome guys!
- Ivica- he is really good dev and guy
- Ghost - as first and awesome betatester!
- Beta tester team that found a bunch of small glitches!
- amarullz for his Aroma Installer
- Romanbb for the original tweaks mod for the Sensation
- lyapota for his media control and other ideas!
- cyanogen for the brightness mod idea
ViperC2 3.1.4.
- (Full rom only)Updated Google Play services, Gmail and Search to android 4.4 version
- Improved larger games and apps performance by increasing dalvik heap size
- Added Fstrim script on each boot
- LPA now disabled by default
Sensation only: - Removed ADSP firmware from Boot.img
- Kernel updated to SebastianFM 1.0.3
- Fixed camera burst mode
- Fixed camera HDR crashes
- Fixed random games crashes
- Fixed random glitches
- Added voltage control interface to kernel
- Fully fixed autofocus and touch to focus in Camera and Video mode
ViperS JB 3.1.3
Added VilleC2 support
Some fixes in KSM control
Added PnP mgr control
Update market apps
Sensation only: fixed lowmem values in Ramdisk, should fix crashes and make phone snappier
ViperS JB 3.1.2
ViperS JB 3.1.1
Update market apps
ViperS JB 3.1.2
- Kernel: Updated to 3.4.10-SebastianFM-1.0.2
- Kernel: Fixed issue with random kernel crashes on some devices
- Kernel: Added KSM
- Kernel: Optimized memory layout
- Kernel: Updated ION, ondemand governor, GPU, Android Binder and Android Low Memory Killer drivers from newest HTC One kernel
- Fixed low and distorted sound on speaker caused by incorrect audio and voice calibration
- Fixed audio amplifier volume levels for headphones
- More free RAM
- Fixed CPU speed changing in aroma
- Re-fixed headset type changing
- Updated Play store and all store apps
- Sidepanel: added quick settings, clock, battery info
- Sidepanel: added ability to select what views you need
- Added KSM control in tweaks
- Added venom logo in about phone settings
- Removed 2d GPU OC in tweaks
ViperS JB 3.1.1
- Kernel: Updated to 3.4.10-SebastianFM-1.0.1
- Kernel: Added NTFS support and CPU freq stat
- Kernel: Added swap support
- Updated aroma to 2.70B6
- Completely redesigned aroma theme
- Fixed auto focus and touch focus
- Fixed incorrect camera lens correction
- Fixed incorrect camera orientation and main camera swapped with front camera in some apps
- Fixed low in-call audio
- Fixed fonts installation
- Fixed opening weather disabled beats audio
- Fixed headset type changing
- Fixed wrong storage size in status bar
- Fixed OTG support
- Fixed MMS sending
- Fixed lockscreen notifications for Hangouts, and some other apps
- Fixed long hold power button for APM
- Fixed extended appdrawer size
- Fixed Sony Bravia
- Increased capacitive buttons vibration a bit more
- Added button backlight notifications
- Added flashlight notifications
- Added LPA toggle in sound enhancer
- Added FR, HR, TR translations in HUB
- Updated TuneIn Radio, Google Now, Gmail, Google Plus, Google Maps, Dropbox, Adobe Flash Player
Major bugs(high prioritiy):
Minor bugs(low priority):
Kernel bugs:
- NONE
ViperS 3.1.4
ViperS 3.1.3
ViperS 3.1.2
Mirror 1 - Full ROM - dev-host
Mirror 1 - Update from 3.1.1 to 3.1.2 - dev-host
Mirror 1 - Kernel Flasher for S-ON users with 1.0.2 kernel
ViperS 3.1.0
ViperS 3.1.1
ViperS 3.1.2
ViperS 3.1.0
ViperS 3.1.1
