19-6-11[SD]-[Jaguaralani Android Gamer's Edition]-[DS][K:H8.6]-[ULTRA SMOOTH & FAST]
jaguaralani
This is a HIGHLY TWEAKED, ULTRA SMOOTH and FAST FULLY FUNCTIONAL ANDROID DESIRE HD2 SD ROM, DEDICATED ESPECIALLY FOR GAMERS, AND ALSO READY FOR DAILY USE....
Rom Base: Desire 3.32
Kernel : Hastarin 8.6
Rom Specifications ( ChengeLog )
-Highly optimized Desire Rom for ultra performance + smootheness.
-Highly stable.
-Tweaked for best CPU-GPU performance for Gamers.
-Ready for daily use too.
-Removed Sense and related widgets for better rom performance, replace by another launcher ( any 3rd part launcher can be used ).
-Battery Consumption = 4-6 mAh.
-Fully De-Odexed.
-Languages=WEE+RTL
-Themed ( Thanks to esk02k )
-Enjoy, Original+Google+MIUI Cameras.
-You may use ChainFire's Application.
What's Working:
Everything apart from SENSE and related Widgets..
What's not Working:
Tell me please...
Download Link:
http://hotfile.com/dl/121315057/5827164/Jaguaralani_Gamers_Edition.7z.html
Installation:
Download the rom.
Unzip using 7zip.
Put "JaguarGE" folder on the root of your SD card.
Run CLRCAD then HaReT....
If you like my work, please consider a small donation, it will really motivate me to work harder...........
https://www.paypal.com/cgi-bin/webs...=PP-DonationsBF:btn_donateCC_LG.gif:NonHosted
diepthao
bản rom dùng rất tốt , không hao pin . chạy ổn định, tuy nhiên không có power control widget trên status bar.
