hoangnam8820010
TESTED ON NOKIA 5800 ONLY
1. New Improved KS Mod.zip - Improves Kinetic Scrooling to a great extent and makes the phone faster
2. Bootscreen Mod.zip - Edit the file to change stastup sound and bootscreen image location
3. Cache Increase Mod.zip - Edit the files to change cache size and more
4. Default Ringtone Mod.zip - Edit the file to change the default ringtone path and name
5. Camera-Quality Mod.zip - Improves Camera Quality a lot
6. Camera-Sound Mod.zip - Mutes the camera sound when the warning tones in profiles are turned off
7. Starter.zip - Disables auto startup of applications like clock, messages, log etc (Saves RAM)
8. Landscape-HS Mod.zip - Enables landscape in homescreen
9. Cache Drive Change Mod.zip - Changes cache location from C: to E:
10. Menu Mod.zip - Adds custom folder icons to menu (Folders like Navigation, tools etc)
11. Gallery Mod.zip - Edit the file to change what folders are monitored by Gallery folders
NOTE: Edit attached file as follows
0x1 string - for C drive HERE U HAVE TO PUT THE FOLDERS THAT U WANT HIDE FOR THE NOKIA GALLERY on C
0x2 string - for E drive HERE U HAVE TO PUT THE FOLDERS THAT U WANT HIDE FOR THE NOKIA GALLERY on E
12. Default Theme Mod.zip - Edit this file to change the default theme(sound waves) to any theme that gets applied automatically during a hard reset
NOTE: If you remove the sound waves theme. You need to set another theme as default that will automatically be applied after a hard reset.
To do this, use nokia editor, open rofs3>private>10202BE9>101F876F.txt
Then see in the last line
"0x14 string "200157FB" 0 cap_rd=alwayspass cap_wr=alwaysfail"
Just change 200157FB in the line to the folder name of your chosen theme in resource folder (resource\skins\******xx)
13. Custom Version Mod.zip - Edit the file to change the custom version name of your CFW and even the date installed
14. Folder Creations Mod.zip - Edit this files and change commands as in Windows Command Prompt to make your 5800 automatically create custom folders of your choice in MMC and Phone memory after a hard reset.
15. Rom Patcher Auto.zip - Put the file in given location to make RomPatcherLite in your CFW autostart.
16. Busy Circle Change.zip - Just place in given location to have a new busy circle over your running applications in your menu.
(It's a tiny blue black coloured curve instead of the default booring green busy circle)
17. Zylam Marex Menu Mod.zip - Use this mod to change your default menu and folder icons.
Use as instructed in the zip file
[The No. 10 - Menu Mod.zip is also a good alternative to this, try it] WinkLocation: Use as directed in the ZIP file
18. Application policy Mod.zip - Edit this file to change user capabilities and application installation settings
19. Stop Nokia SMS Mod.zip - Place this file in given location to stop your phone from automatically sending SMS to Nokia after a
flash or hard reset operation
20. All patches.zip - Contains all available Rom Patcher patches for Nokia 5800
I placed this folder directly on Z drive. Rom Patcher works perfectly fine and till now I faced zero reboot problem!
21. MIF Maker.zip - Use this tool to make MIF easily. Create your own splashscreens and shutdown screens
22. Hidden Menu Mod.zip - Extra shortcuts in Menu: Connection manager, Themes, Profiles
23. Music Player Mod.zip - Music player reads only E:/Music, create the folder and place your music files there!
24. Java permision mod.zip - Look into app manager/installed/"your installed Java apps'/options, see everything is always
allowed and no more anoying notificatons!
25. Widget security disable Mod.zip - Disable annoying widgets security warningsLocation: Use as directed in the ZIP file
26. File Transfer Mod.zip - Place this file in given location to get all received files directly on E:/Received. Don't forget to create the folder "Received" in your MMC. Or you may edit the file as you like
27. Multi Mod.zip -
IMPORTANT: This mod is an updated and combined version of Mods No.15 and No.19
Use this Mod instead of No.15 and No.19 Mods
Place the two files in given location and get these results:
1. RomPatcher Autostart
2. No Nokia SMS sending after hard reset or flash
3. Fast Boot up (Optimized for speed)
4. More free RAM on startup (I got 70.12 MB)
NOTE: Remove welcome2.exe from rofs2/sys/bin if it's there. I didn't like the idea of a dead "Phone
Setup" icon on menu. The Nokia Welcome or Phone Setup application in menu will work....only it
will not autostart and send sms automatically after a hard reset or a flash. I did this so that you
can use the "Phone Setup" application if you need later..
28. Lock Unlock Mod.zip - No more vibrations now when lock unlock screen with side key even when vibrations are turned on in profiles (Thanks to GOC)
30. Improved Camera Sound Mod.zip - Use this mod to remove camera beep (taking photos and video) when warning tones in profiles are ON!!!
31. SmartSIS.zip - Anyone having problem with MIF Maker, use this software to convert JPEG or SVG to MIF
INFO: Requires Python 1.4.5 to run
32. Improved Caching Mod.zip - This mod is an updated version of No.3 Mod.Use this Mod instead of mod No.3 . Place files in given location for improved caching on all drives
33. Heap Size Mod.zip
This Mod Increases System Memory Heap Size and decreases Application Delay and Close Time
34. Camera mute Mod.zip
Another alternative to mute the camera sound even when warning tones are ON! (Stick to "Camera 1" as camera capture tone)
**credit to naughtypope
35. Changing default ringtone (to gasolina tone)
If you want 'Gasolina' as default ringtone, use "Gasolina.zip"
Another way:
1. Either use mod No.4 supplied here and then edit the file to target to your ringtone file
2. Or convert your favourite tone to "aac" format and place in rofs2/data/sounds/digital and rename it as "Nokia tune.aac".
36. Fixed HS.zip
Get 5 Homescreens for Nokia 5800
1. Contacts Bar
2. Full Page (6 icons)
3. Finger Use (8 icons)
4. Navigation Bar (Satio)
5. Omnia HD (Basic)
37. AIO Homescreens
Use either this Mod or Mod No. 36
Download MODs here: http://adf.ly/1E2lj
Source: mobimas blog
Bài này đi sưu tầm về, có gì mấy bro bỏ qua cho.
27. Multi Mod.zip -
Another way:
36. Fixed HS.zip
1. Contacts Bar
5. Omnia HD (Basic)
37. AIO Homescreens
