ASUS P535 - ROM WM6.5 PDAVIET (Build 21501.5.0.70)
khacduy1978
ASUS P535 PV-ROM WM6.5
CE OS 5.2.21501 (Build 21500.5.0.70)​
Special Thanks:
Super Mod PhamQuang
RomDev Sonblack
RomDev Dvha79_ddt
Mod Ancola66
PDAmobiz.com & XDA-Developers.com
Tranh thủ rảnh rỗi làm cái Wm6.5 cho anh em test thử. Nghe nói build này là bản chính thức đó.
Link download: http://www.mediafire.com/download.php?2ey2yyximjz
Hình minh họa:
earthquake
so no more beta 6.5 roms then, thats good. I will wait out a new version, otherwise I'll try it. thanks a lot =D>=D>=D>
youbeetea
This ROM broke my phone :((
The initial checksum an language checks were successfull. Then my phone started the update procedure. The update procedure failed having a checksum error.
Now the phone does no longer accept a GalaxyII.nb0. They all have a wrong language version.
Any idea, what can be done?
youbeetea
I can no longer start Windows Mobile on my phone. After reboot I get the blue Asus screen. The boot procedure is finished at that point. WM is no longer found on my phone. Therefore I cannot start AsusUnlockID.exe.
I'm now looking for a GalaxyII.nb0 that is accepted by my phone. The GalaxyII.nb0 coming with Build 21501 is said to have the wrong language (the language was accepted for the broken update). I also can't reinstall the previously used ROM (same problem: wrong language). I downloaded the original firmware (language=GER_DE00) and used P535RomTool.exe to extract GalaxyII.nb0 from AsusP535.cap (same problem: wrong language)
I also tried the original WWE_EN00 and some other ROMs, but none í accepted.
qqonline33
Bản này đúng là nuột. Hehe. Bác Duy tích hợp thêm QuickMenu --------> Chuẩn không cần chỉnh. Merci bác Duy nhiều nhiều
toruhea27
bản này có bị lỗi khi cài Spb Mobile Shell v3.0.0 Build 6362 rồi thì k dùng được camera ( hoặc bật được camera sau mỗi lần RS ) như bản ASUS P535 - ROM WM6.5 PDAVIET (Build 21500.5.0.0) k a?
alanlee
Rom này mình dùng SBP Shell build 6411 thấy chụp hình quay phim ngon lành ;)
blackmaskvn
Bản này xài được bàn phím tiếng Việt không ta? Có ai thử chưa, bản 21500 cài được nhưng không xài được...
qqonline33
Bạn cứ thử đi. Cá nhân mình thấy bản này có vẻ đã thực sự hoàn thiện, chưa thấy cài phần mềm j mà bị lỗi cả.
alanlee
Bạn giúp mình cài thử PhoneAlarm pro 2.13 thử xem, mình cài xong mà mỗi lần khởi động lại thì rất khó load vào, chỉ dừng lại ở màn hình today gốc với các chấm màu xoay tròn :-/ mà không vào SPB MShell 3.0 :|.
Mặt khác, mình cảm thấy 6.5 khởi động chậm hơn 6.1.
vik2
hello everyone!
sorry my bad English!I would ask help in it,that 6.5 hit me SPB3 v6456 and S2U2 1.6.A S2U2 1.6 do not display half of the caller's picture and the weather panel.WM Under 6.1 on all of them ok.thx
chaosnever
Thanks for the great build! It is fast and stable. I have found one problem using it - when somebody is calling me, the dialer does nỏt recognizes the numbers from my SIM. It is only showing the nuber, but not the name. I have changed the area code, the numbers are written in the SIM with the country code, but no result. Please, help!
khacduy1978
Edit registy to show SIM in contacts:
[HKEY_CURRENT_USER\ControlPanel\Phone]
"ShowSIM"=dword:1
