ASUS P535 - ROM WM6.5 PDAVIET (Build 23004.5.3.0)
khacduy1978
ASUS P535 PV-ROM WM6.5
CE OS 5.2.23004 (Build 23004.5.3.0)
Special Thanks:
SM PhamQuang
AM Sonblack
AM Dvha79_ddt
Mod Ancola66
PDAmobiz.com & XDA-Developers.com
Bản Rom này không thay đổi so với bản trước. Chỉ thay đổi OS mới mà thôi. Cảm nhận cá nhân thì bản này chạy nhanh hơn các bản trước. Các bạn cùng test thử nhé.
Link download: ASUS P535 PV-ROM WM6.5
CE OS 5.2.23001 (Build 23001.5.0.60)
Special Thanks:
SM PhamQuang
AM Sonblack
AM Dvha79_ddt
Mod Ancola66
Bản Rom này không thay đổi so với bản trước. Chỉ thay đổi OS mới mà thôi. Các bạn cùng test thử nhé.
Link download: http://www.mediafire.com/download.php?j03mzd241el
Một vài hình minh họa:
f50fd
hi, thx for the update, but seems the link is not update, isn't it? thx again
ForceField
I also noticed a problem on the icons.
The selected state of the icons has a problem:
When you click on it it shows some weird graphics
vihali
Thanks,
What is new in this room?
Please give some info.
He said in Vietnamese
meaning that this version is not much different to the previous one except the OS. You guys'd better start learning Vietnamese :)):)):))
vihali
Xin lỗi sự khác biệt đã được viết xuống thật sự. :)) :D
:)):)):)) No VNmese can understand that sentence. I guess you have used some translator engine so I tried to convert it back into English, providing no idea about its root language.
It becomes
Sorry difference was actually written down
Haha, that really sucks! But it's a nice try anyhow.
BTW, why don't you try using translator engine to get the meaning of the very first post? This is how it works, not so perfect but hope you still get the idea
Rom version is not changed compared with the first. Just change new OS only. Personally feel it is running faster than the previous version. You try the same test nhé.
The last sentence should've read "Let's try it (together)"
DuaBeo35
Ặc ặc không biết thằng ku nhà mình nghịch cái j mà cái đồng hồ trên Start menu biến thành ... analog????
Tìm mãi không biết chỉnh chỗ nào? Bác nào biết chỉ giùm mình với hic hic
ROM này khá mượt.
Có điều thằng win 6.5 này rắc rối quá. Cứ khi nào cài thêm chức năng vào thằng Cpanel hay thay đổi icon... là nó thanh đổi themer... vãi.
qqonline33
ROM này khá mượt.
Hơ. Bạn dí vào cái analog ấy,là nó cho chọn thành digital ngay í mà...
