ASUS P535 with WM 6.5 - first time EVER
gxg
I managed to make it work. LE. AND IT's FIRST TIME POSTED HERE.
For first time, I proudly present to you the new ROM with WM 6.5 interface build 21159 5.0.0.
I don't have time to make screenshots, but you can trust my word. Full functional.
IE is 8 but I advise not to use it.
Issues noticed:
-After a while, display goes to "Suspend" mode. Just have to push power button to wake it up.
- press the location of keyboard and choose full keyboard (opal skin keyboard) otherwise you'll not have keyboard.
Camera is with the latest driver.
All is working.
I'm attaching some pictures here just to know what is all about.
Over all you don't imagine how nice is the interface.
Download link:
http://www.mediafire.com/file/onglrmzlnzd/GalaxyII with office.nb0 - 128 Mb RAM (Works with 64 by default)
- Ram optimizer (Oxios hybernate)
- Pocket Rar
- Windows Live
ancola66
Thank you for your collection and sharing but have 2 problems need to be clarified :
1-The picture by incorrect Asus p535 (Picture 2)
2-Rom version supports 64 or 128 ram? ( in PDAMobiz introduced to support 128? )
gxg
http://www.pdamobiz.com/forum/pdaforum_posts.asp?TID=197475&PN=1
Not really the first time ever mate but thanks anyway.
tehnicaly for 21195 in P535 is the FIRST TIME EVER :-?
Man... it was 2.30 in the morning.. I've posted some pictures.. just to make an ideea. I specified that those are not pictures taken from device.
Anyway.. I will upload both versions. 64 and 128.
L.E. Done.. both versions.
Ancola..I didn't know that it's needed to use Unlock.ID... in mine.. it worked without it from first time. ;)
LeSScro
I made modification on 128 Mo release...
Change CPU... change Lang ID to 409 (because in original ROM by GXG, 419 Russian language make me an error update failed, but i have unlock my PDA)... Change Pagepool :6
make a SPB backup ;)
install new ROM...
and now...
i think Picture say better than Word...
WM6.5 is smother and fast... Time reponse is very impressive
the new ability to scroll is awesome, the new Start Menu is funny...
Now need install Progs to view compatibility...
THX GXG... Really Good Work
qqonline33
Thanks for ALL. I'm waiting for rom WM6.5 which made in PDAViet... Hope it coming soon...
LeSScro
FeedBack...
This ROM is Stable... i found a good RAM gestion... in this WM6.5, better compatibility than RÔM 6.5 From PDAMobizwith applications (only prog to custom windows have some problem, depend to method to change Windows ability)...
>I need install WKtask because X/OK button don't close programs...
>With Sktools, i can tweak menu but i can't change the Blue On Menu... other background,Size Font menu, Font Menu can be change with Sktools...
>Start Menu seems to be different but we can change all icon like WM 6.1...
>Device Lôck is simple but Efficace... i m trying to adapt the same Style on my new Skin...
because i can install Wisbar Advance Desktop...:D
Continue my investigation...
Good Job !
gxg
And it took only 5 hours assiduous work to make it like this.
my only drawback is that Weather widget's not working... not for now. :(
Lesscro..if you have Sktool which is not trial..please share it.
LeSScro
i can share here a cr@cked version ?
if i can, i have the latest... >:)
ForceField
Just downloaded and it's a very Good ROM.
I also noticed that this rom conserve battery power.
btw,Is there a way to skin the 'X' and the 'OK' buttons.
Your releases are great gxg ,thanks
LeSScro
use wktask... then OK/X close really apps and works muck better !
earthquake
im using wktask and when im open the start menu and tap the X button windows says an unheandled error has occured in the shell attemptring to restart the shell and my devices resets itself :(
Các KTV nhà ta đâu hết rồi mà lâu không thấy ROM WM6.5 "cây nhà lá vườn" nhỉ?
Để ROM Tây "lấn chiếm" thế này xấu hổ quá !!! :O:O:O
ZHIHWA
Seo mà tiếng mẽo không ah. Tưởng là vào nhầm trang modaco nữa :(
Bác Quang làm thêm 1 bản cho tụi nó biết nhé. Sẵn cho cháu ăn ké tý. Thank Bác nhiều.
qqonline33
PDAV Mod đang bận j ấy. Mãi ko thấy động tĩnh j cả. Vẫn biết gia nhập WTO là tốt. Nhưng chắc phải tăng thuế nhập khẩu lên thui...:(
