ATOM LIFE - PDAVIET ROM 6.1 (Core 19949) by TranMinhMan
TranMinhMan
PDAVIET ROM WM 6.1 CE OS 5.2.19949 Build 19949.1.2.0
By TranMinhMan
--- Only for Atom Life ---
Đặc biệt cảm ơn - Special thanks to:
Man PhamQuang
Admin Kawaguchi
Mod Sonblack
Mod Medkid
Trial Mod PhamNhatThanh
Thông tin bản ROM - ROM Informations:
- CE OS 5.2.19949 Build 19949.1.2.0 PV T2M from ROM WM6.1 Sony Xperia X1
- Pagepool: 6M
- .NET Compact Framework 3.5
- Adobe Flashlite 2.1
- Adobe Reader LE 2.0
- Advanced Configuration Tool v2.02.0.1.0 by Schap
- ClearTemp v1.0.1 by Vicott Wong
- Contacts Manager extension v1.6 by FdcSoft (support copying many contacts from Phone to SIM)
- Esmertec Java Build ID: 20080222.3.1
- Free Mem
- HTC Sim Manager for Pocket PC v6.47
- Mode SMS (change message display on PPC)
- PHM Registry Editor v0.7 by Philipe Majerus
- PIM Backup v2.8.0.0 by FdcSoft
- PocketNotepad v4.0.10
- Pocket RAR 3.60 by Alexander Roshal
- Synchro Time v0.94 by Dennis Grachov
- Total Commander CE v2.5 by Christian Ghisler
- Windows Media Player 10.3 Build 19949 skin HTC Diamond
- Comm Mannager skin HTC Diamond
- HTC TouchDual HomePlug Diamond
- Dialer NikiBlack Diamond
- Task X Button v1.51 by High Tech Com. Corp.
- Bettery Status v1.05
- Thay đổi các icon mới.
- Change new icons.
Phần mềm đã loại bỏ - Programs were rejected:
- Welcome center
- FTouchFlo
- psShutXP
- Screen Capture
Hướng dẫn up ROM - Up ROM Guides: (up từ thẻ nhớ - up from MMC)
- Thẻ nhớ nhỏ hơn 2G, format FAT16 (trên PC là FAT).
- MiniSD is smaller 2G, format FAT16 (on PC is FAT)
- Download và giải nén với password bên dưới, chép file AL1.DIO vào thẻ.
- Download and extract with the password below, copy file AL1.DIO to MMC.
- Nhấn Record + chọc Reset, buông Reset trước --> ***MiniSD Detected*** --> chờ 100% máy tự reset là đã có ROM mới!
- Press Record + Reset, leave Reset first --> ***MiniSD Detected*** --> waiting 100%, Atom Life auto reset and you have new ROM!
Link download bản sửa lỗi Beta test đã được cập nhật lại ở bài 2.
Download links the version fixing Beta test were at post #2.
Chúc vui!:D
Enjoy it!
:D
TranMinhMan
Thông tin - Informations:
- Sửa lỗi hiển thị Beta test khi cập nhật thời gian sau ngày 14/06/2008.
- Fixing display Beta test error when update the time after 14/06/2008.
- Tối ưu free Ram một cách tốt nhất.
- Make best-case for free Ram.
- Có lại psShutXP.
- Replugin psShutXP.
- Nhóm icon cho hợp lý hơn.
- Group the icons logical.
Phần mềm loại bỏ - Programs were rejected:
- Audio starup.
- Autoupdated.
- Transcriber.
- VoiceCommand.
Links download tại đây
Links download were here
Link 4Share
Link RapidShare
Password: TranMinhMan
Chúc vui!:D
Enjoy it!:D
Sonblack
Cuối cùng rồi chú em nhà ta cũng chỉnh xong hỉ!
Thấy hay chưa? Offline cũng có giá trị của nó chứ bộ! =))=))=))
Chào mừng ROM mới, sôi động cùng EURO 2008!
imatrix
well done. thanks
I see you skinned the calculator (not sure about the phone pad skin).
would you mind provide wm7 skins for both calculator and phone pad?
thanks
CÁI NÀY CÓ BỎ CÁI GIAO DIỆN VÀ ÂM THANH LÚC KHỞI ĐỘNG CHƯA PRO.
DÙ SAO CŨNG THANKS PRO NHA. AI UP RỒI CHO EM 1 VÀI ĐÁNH GIÁ ĐI, THẤY GIAO DIỆN ĐẸP QUÁ.
KHÔNG BIẾT UP ROM HOÀI CÓ BỊ ẢNH HƯỞNG GÌ ĐẾN MÁY KHÔNG TA.
CÁI Pagepool: 6M LÀ GÌ VẬY PRO.
TranMinhMan
Bootscreen và Audio Boot ko ảnh hưởng nhiều tới việc boot nhanh chậm đâu bạn. Sở dĩ những bản ROM sau thường boot chậm hơn là do mình nhúng nhiều phần mềm hơn so với những bản ROM trước, cần có thời gian khi load ctr. Nhưng nó chỉ hơi lâu khi bạn HR sau khi up ROM xong thui mà, chứ khi bạn SR thì nó boot tốt đó chứ. Bạn có biết khi bỏ bootcreen thì màn hình boot của bạn thế nào ko, màn hình thì tối thui còn đèn thì đỏ lè như là máy sắp die vậy!
Bộ nhớ của ĐT là theo dạng thẻ flash, nó được tính tuổi thọ theo số triệu lần chép xóa. Cho 1 tuần bạn up ROM 1 lần --> 1 tháng 4 lần --> 1 năm khoảng 50 lần. Vậy thì bạn up tới lúc chán chê cái máy thì cũng chẳng sao!
Còn pagepool là gì thì bạn wa đây tìm hiểu thêm.
Chúc vui!
:D
TranMinhMan
well done. thanks
thanks
Tks for your idea!
But I think this Diamond skins are more suitable than WM7 skins, so I put them to this ROM.
Enjoy!
:D
tienha
rom này k bỏ hẳn O2 menu rùi hả Vanlydochanh :D hôm trước mình chạy O2 theme nhưng nó đòi chạy cùng ctr O2 connect,bùn thế,dù sao cũng thanks nhìu^^
TranMinhMan
Nếu bạn thích xài O2 Theme thì hãy up bản 19213 và 19212 của mình, 2 bản này mình giữ gần như đầy đủ các ctr original của ROM seeO2.
Còn bản này dùng giao diện Diamond thì ko thể thiếu HTC Home được bạn àh, nên đành loại bỏ bớt vậy!
Chúc vui!
:D
isoftvn
Mẫn ơi cho mình hỏi, cái chỗ +256mA là gì vậy, sao khi mình load ROM này thì số đó lại khác? Có phải là do PIN mình là PIN dõm hông vậy :(
Sined
When I start my atom-life after flashing the rom I got this message "This concludes the beta test of this software release. Thank you..." and I'm able to no nothing !
What should I do ?
EDIT: It's ok now, I got this message because I didn't choose the right date.
isoftvn
Sau khi up ROM và test mình xin có một số ý kiến như sau :
1/ Hình như ROM này chạy hơi bị tốn RAM, hic hic khởi động xong free RAM khoảng 11MB àh.
2/ Cái plugin x-Button có lẽ không cần thiết, do cái plugin batterystatus cũng có chức năng này rồi mà Mẫn
3/ Giao diện đẹp, sử dụng rất smooth :)
Mẫn xem lại cái vụ plugin nhé, nếu có thể thêm 1 release ROM nữa bỏ đi cái x-button chắc nó sẽ nhẹ hơn được chút áh, hy vọng bạn xem lại và có 1 chỉnh sửa nhỏ cho ROM này ngày một tốt hơn
Thanks
1107
Thanks
đâu có tốn ram dữ vậy anh. em vừa up rom này xong ne.sau khi reset ram free gan 23 mb lận.
bản rom này giao diện đẹp quá à. cảm ơn anh tranminhman nha.
Medkid
Nó cho biết máy bạn hiện tại đang tiêu thụ bao nhiêu mA pin ( I thought) :p
tùy thời điểm khác nhau,các ứng dụng đang chạy nền khác nhau mà lượng pin tiêu thụ cũng khác nhau ấy mà.
isoftvn
Có ai có cùng ý kiến ko vậy? Sự thật mình reset hoài mà khi khởi động xong free RAM cũng chỉ nằm khoảng 10-13MB àh, có ai test rồi mà lượng RAM free nhiều như 1107 ko vậy, cho mình biết với nhé.
1107
CÓ AI BỊ NHƯ ÍOFTVN CHƯA VẬY.SAO KHI EM UP ROM, RESET MÁY THÌ FREE GẦN 23MB LẬN. MÁY EM CHƯA CÀI PHẦN MỀM NÀO HẾT.
À SẲN ĐÂY CHO EM HỎI LUÔN LÀ NÊN CÀI PHẦN MỀM VÀ GAME VÔ TRONG BỘ NHỚ MÁY HAY LÀ VÔ THẺ NHỚ VẬY? EM THẤY BỘ NHỚ MÁY TỚI 1GB KHÔNG BIẾT CÀI VÔ BỘ NHỚ MÁY CÓ LÀM CHẬM MÁY KHÔNG VẬY? THÁNK ANH EM NHIỀU LẮM
CHÚC CÓ NHIỀU ROM HƠN ĐỂ ANH EM CÓ THỂ MỞ RỘNG TẦM MẮT. GOODLUCK.
