Mới thấy trên xda-developers, các bạn uprom thử rồi cho ý kiến để anh em tham khảo
NEW BUG FIXES XDA ATOM WM6 AKU0.7.1 WWE (For Evaluation Only) by
UPDATED December10, 2007
Atom/Atom Pure only!!!
download: http://www.mediafire.com/?4xmmtnjif0x
NEVER ATTEMPT TO UPDATE YOUR DEVICE USING SD CARD FLASHING!!!<-(unless you have the know how)
Upgrade Procedure:
1. Put device to bootloader mode: (CAMERA+RESET)
2. Connect device to PC under Windows XP using USB cable
3. Extract files to Windows/Temp then execute Device Software Update Utility.EXE<-(DSUU for Atom Pure)
4. Follow on-screen procedure
Reported Bugs and/or Incompatibility:
CE Star
Bluetooth PAN - not supported yet
O2 PhonePlus conflicts with smart dialing feature of WM6
Ringo
Spb Phone Suite / Mobile Suite
A2DP not working
Known to Work Fully:
Internet Sharing over USB
Intellidialer (PhonePad)
Resco Explorer 2007
Spb Mobile Shell (latest edition)
chi tiết :http://forum.xda-developers.com/showthread.php?t=350576
Upgrade Procedure:
CE Star
Ringo
A2DP not working
Resco Explorer 2007
