AutoSHSH - Tự động lấy SHSH cho iPhone / iPad 3.1.3 và 3.2
dr_mosse
[url=http://hinhanh.123viet.net/share-648A_4BC2EA8B.html]
[/URL]
The software of iH8sn0w to Grab your ShSh file signed by Apple for your Firmware 3.1.3 or 3.2 (iPhone / iPad) is available.
This ShSh file (also called ECID) is signed by Apple and will permit you then in the future to restore this firmware 3.1.3 or 3.2 with iTunes without any issue when a new Firmware will be available.
[url=http://hinhanh.123viet.net/share-2B82_4BC2EBF1.html]
[/URL]
[url=http://hinhanh.123viet.net/share-767E_4BC2F452.html]
[/URL]
[url=http://hinhanh.123viet.net/share-1EA8_4BC2F3CA.html]
[/URL]
  • For Jailbroken or NOT Jailbroken iDevice.
  • Required Java on your computer and an Internet connection.
  • Only for Windows.
  • Connect your iDevice in USB.
[url=http://hinhanh.123viet.net/share-39C2_4BC2F407.html]
[/URL]
  • Must be in Recovery mode (USB cable displayed on the screen) : Hold Home + Power button until the picture with the cable is displayed on the screen of your iDevice.
  • Start the grabbing of your ShSh file.
[url=http://hinhanh.123viet.net/share-C482_4BC2EBF1.html]
[/URL]
  • ECID is identify and sent to Apple server for signature.
[url=http://hinhanh.123viet.net/share-CAE0_4BC2EBF1.html]
[/URL]
  • Save then your ShSh file on your computer.
  • Note : Apple only signs the latest Firmware, then the FW 3.1.3
If you have already your ShSh file signed by Saurik, you can grab it with the software Umbrella : read this.
With this method Umbrella, you can also check if your ECID file has been well saved by Saurik.
Note :
  • Firmware 3.1.2 is not signed anymore by Apple
  • To leave out Recovery mode, Hold on Home + Power button until your iDevice is Off
Why is it necessary to do it ?
For the most recent models (iPhone 3GS and iPod Touch 3G), iTunes can only restore the latest Firmware signed by Apple.
Grabbing your signed ShSh file will permit you to restore the same Firmware for which your ShSh file was signed.
A sotware like tinyTSS will permit you also to restore an old Firmware locally with your own signed ShSh file avoiding Saurik method.
iH8sn0w had announced since a while that they were working on an update of the software iReb, in order to create your own server of verification with your signed ShSh file.
[video=youtube;w2mMkN0cVo8]http://www.youtube.com/watch?v=w2mMkN0cVo8[/video]​
Published by skygoat76
xtafi2002
Cái này là mình đang cần mà chưa tìm thấy giờ nhờ pác mà e có đc. Thanks pác nhiều
scorpionx23x
các bạn ơi. Mình vừa mua 1 con 3GS world 3.1.2, nghe cách bạn nói là phải save SHSH gì đó để dành sau này downgrade (chổ này mình hiểu).
Vậy mình dùng soft này được ko?Vì bạn để "AutoSHSH - Tự động lấy SHSH cho iPhone / iPad 3.1.3 và 3.2 "
Nếu ko, thì đối với 3.1.2 như mình thì cần phải làm sao?
Mình chưa dám là gì hết, muốn chắc ăn 1 cái gì đó để có thể restore dc rồi tập jailbreath thử =.=!
scorpionx23x
Zenki. Cái này tui đả hỏi và có ai trả lời đâu? như vậy có phải là nên đi lập topic để hỏi ko?
Germaniteen
Bạn lấy cái 3.1.2 về mà cất đi, chứ mai mốt không có mà xài đó .Hết downgrade luôn!
scorpionx23x
dạy mình làm cách lấy SHSH của 3.1.2.như thế nào đi?
Restore thì có thông báo sẽ update 3.1.3, như vậy mình phải làm sao? Làm ơn nha bạn.
thangna
sao bằng tiếng anh cả thế này, đâu phải ai đọc cũng hiểu đâu. a e nào thông thạo dịch giùm cái
Hugo206
Theo em biết thì bây giờ chỉ lấy đc file SHSH cho 3.1.3 thôi phải kô? Và máy e là bootrom mới nếu tắt máy để lấy thì có nên kô?? Em cám ơn
hungdqk
Thế bay giờ mà dùng cái này thì có lấy đươc shsh của fw 3.12 bb 5.11.07 ko các bác ơi để còn dow về
vipboy_9x
hiện tại chĩ lấy được SHSH 3.1.3 mà thui.và tooj này cũng chĩ hoạt động trên 3.1.3
