nguyenthuanbg_pv
[WM6.5] Prophet 23075 babak00000 OC1 (Optimized Clean) ROM
- Cảm ơn tác giả Babak00000 =D>
- Các pác thử đi nào và cho vài nhận xét nhé =D>.
Based on Bikertibi's 23075 ROM (Many thanks to him, for his efforts to bring WM6.5 to our Prophets, and for what I've learned from him and his ROMs)
Asian Support by dioxda2
(Bugs fixed, stable, and fast)
Special features:
- "X", really closes the applications. No need to use "End Task" in "Task Manager", anymore.
- ~63 MB total storage, ~ 61 MB free storage.
- ~29 MB free RAM without Titanium plug-in (default) and 28 MB with Titanium plug-in.
- 4 columns in portrait and 5 in landscape mode in start menu.(You may change it....)
- Windows files optimized. (a fast ROM)
- Some files moved to Extended ROM (Unlocked and totally used!)
- Customized Camera Loader.
Other features:
-.NET Compact Framework 3.5
- Office 2007, including PowerPoint
- iSS Calculator Pro 1.0.1
- No MMS (but cab is provided.).
- HTC Network Wizard
- HTC SIM Manger
- HTC Diamond CommManager
- Magnifier
Titanium plug-in:
- Titanium plug-in is not enabled by default. Enable it from Start -> Settings -> Home -> Items -> Windows default , if you want.
Camera:
- Camera drivers are not loaded by default. They will be loaded automatically each time you press the camera button, and unloaded when you close it by "X". Just use it!
- Camera may become locked if you don't close it with "X". Simply use "Unlock Camera" from "Camera Utilities" in "Start" menu to unlock it, if it occurred.
- Load/unload drivers temporarily from "Camera Utilities" in "Start" menu to use other camera software (eg. CoolCamera). No restart is mandatory.
- Use following Cabs to permanently load the Camera drivers or to unload them (as the default setting). Device should be restarted to take effect.
Permanent Camera Disabler / Enabler:
Load Camera Drivers Permanently-for OC ROMs.cab
Unload Camera Drivers Permanently_Default-for OC ROMs.cab
X button:
"X" closes the applications, by default. Use OK (Hard-button) to maintain them in the memory (the windows default).
"Start" Menu:
To see original setting in WM6.5 (3 columns in portrait and landscape):
P3_L3 (Original) for WM6.5.cab
Current "Start Menu" setting:
P4_L5 for WM6.5.cab
Larger Fonts in "Start Menu":
Large Font Start Menu for WM6.5
Magnifier:
Tap the taskbar to see its icon.
MMS:
Use this cab to install it if you want MMS.
ArcsoftMMS_5_0_31_7_OC.cab
Letter Recognizer (cab provided by our great chef, bikertibi - link to his post):
It is disabled to save more memory and to enhance the boot time as many people usually do not use it.
Use the fallowing cab ( registry tweaks) to enable it if you want. (No reset is needed)
Enable Recognizer wwe.cab
Download:
WWE: http://www.mediafire.com/?q0lwjktzfjx
Asian Language Support (by dioxda2 -Link to his post with screen-shots):
#1. download ROM (nbf file) from 4shared- 23075 - Asia Locale support
#2. download from Rapidshare - Chinese input and Fonts
Thanks to dioxda2 for Asian Support.
Thanks to Da_G, inteks, and amarullz.
Special thanks to bikertibi for the base ROM and the Prophet_Upgrade utility, included in this release.
Thanks to rusasbmw for bug reporting.
Thanks to Jooly also for editorial bug reporting.
Unload Camera Drivers Permanently_Default-for OC ROMs.cab (2.0 KB, 66 views)
Special features:
Other features:
- HTC SIM Manger
- Magnifier
Titanium plug-in:
Camera:
X button:
"Start" Menu:
P4_L5 for WM6.5.cab
Magnifier:
MMS:
Download:
