CongVoi
BallRoom UIQ3 1.20
Xin giới thiệu với các phần mềm mới nhất của công ty cellphone.Công ty này quá nổi tiếng với phần mềm swiss mgr pro,quá kinh điển luôn.Công dụng chính của chương trình này là: Hiện thị thời gian,hoặc hiện thị bộ nhớ Ram...
Product: BallRoom UIQ3
Version: 1.20
Genre: System enhancer
Availability: Download
Documentation: User Guide, FAQ
Languages:
Compatible devices:
Synopsis:
BallRoom provides a unique opportunity of customizing your phone's appearance and functionby taking over the upper-left corner of the screen, where normally an idle application icon is shown.The program lets you change what is displayed in the application icon area,and define what action is performed when touching that areaa
2v:G,R9J)V2m.e3S
BallRoom divides the icon area to two independent parts where you can display various dynamic contents,including time, date, free memory, battery level, and more.Even an animated image can be shown!By touching the icon area you can perform various actions,like step through running tasks, or launch and exit programs
The top-left corner of the phone's screen used to be like a vacant ballroom where no-one is having a dance.Using BallRoom you can fill in the room with lively contents, even bouncing balls, if you want to do so.You can make the BallRoom icon permanently visible,so that your custom icon is always there to provide information or to perform a task.
Major features:
Permanently replace the top-left screen area, optionally including over full-screen applications. Selectable display contents include time, date, free memory, battery level, and image. Selectable actions performed when touching the icon include application launch, task management, and more. Content and action can be separately defined for icon regions. Ability to add permanent animation to the phone.NEW in version 1.20:
Support for permanent display of the BallRoom icon. New action type to launch applications on icon tap. New option to display action icons. Improved performance and reliability. Numerous additional enhancements, optimizations, and bugfixes.
Các bạn có thể thay đổi ảnh cho nó nữa.Dưới đây là 3 ảnh khá đẹp giới thiệu các bạn dùng chơi:
Đây là ảnh thay rùi nó sẽ hiện ở góc trái màn hình trong Menu:
Version: 1.20
Languages:
![Flag5.gif](http://www.cellphonesoft.com/image/Flag5.gif)
Compatible devices:
![CompatUIQ3.gif](http://www.cellphonesoft.com/image/CompatUIQ3.gif)
Synopsis:
2v:G,R9J)V2m.e3S
Major features:
![br_anim_spec.gif](http://www.cellphonesoft.com/image/br_anim_spec.gif)
![br_anim_240.gif](http://www.cellphonesoft.com/image/br_anim_240.gif)
![20080523_cd9bfe5b4ae80db2c3e4oeLQSWbzNs95.gif](http://wda.com.cn/attachments/month_0805/20080523_cd9bfe5b4ae80db2c3e4oeLQSWbzNs95.gif)
![20080523_3fc49a74d48f2925e357ZFupmbQBIpEQ.gif](http://wda.com.cn/attachments/month_0805/20080523_3fc49a74d48f2925e357ZFupmbQBIpEQ.gif)
![20080523_971622eb568a0e63fc88Jt0jn4YVCZu9.gif](http://wda.com.cn/attachments/month_0805/20080523_971622eb568a0e63fc88Jt0jn4YVCZu9.gif)
![20080523_77ec704fee0084b7960aKOleFGgX9MHz.gif](http://wda.com.cn/attachments/month_0805/20080523_77ec704fee0084b7960aKOleFGgX9MHz.gif)
