Các bạn có thể xin chi tiết ứng dụng này trên Google Play: https://play.google.com/store/apps/details?id=com.fulminesoftware.batteryindicatorpro
Unique, exclusive battery indicator in status bar with widget!
Battery Indicator is a lightweight application that displays battery information in Android's status bar and home screen.
Is android battery level indicator not enough for you? This app solves this problem.
Key features of our Battery Indicator are:
- Unique, elegant graphics with exclusive character.
- Many configuration options (and still growing) - you can enable or disable and adjust many functionalities.
- Home screen widgets.
- Displays estimated time left to fully discharge or charge.
- Displays colorful icon with exact percentage of battery level in status bar with one-percent accuracy.
- Big readable digits in status bar.
- Quick access to more details by sliding down from top of the screen to show Android notifications or by clicking on home screen widget.
- Displays current velocity of charging or discharging (in percent per hour).
- Displays last charging and discharging statistic information (time, level range, velocity).
- Indicators colors are changing depending on battery level and state.
- Two view modes: standard and detailed, switched quickly and easily by sliding panel.
- Many detailed information, such as temperature, voltage, health, plugged state, battery technology, time from last status change etc.
- One percent accuracy.
- Quick access to Android's "Battery usage" screen.
- More coming soon.
Application is currently available in following languages:
- English
- Polski
- Français
- 한국어
- Nederlands
- Tiếng Việt
- Română
- Pусский
- Español
- Українська
- Italiano
- Ελληνικά
- Čeština
- Português
- Português Brasileiro
- 中文 (简体)
- Magyar
- Deutsch
- Srpski
- Türkçe
- עברית
- Slovenčina
- العربية
- Монгол хэл
- 日本語
- 中文 (繁體)
- Bahasa Indonesia
- Norsk bokmål
- Bahasa Melayu
- Svenska
- Galego
You can become our translator - see details in application.
Ứng dụng hỗ trợ nhiều thứ tiếng trong đó có tiếng việt nhé các bạn
Còn các bạn có thể tải miễn phí ở đây nhé: TẢI VỀ
