gaupretty
Battery Tracer - App rất PRO giúp bạn theo dõi PIN của iPhone !
Battery Tracer
Category: Utilities
Price: $0.99
Released: Sep 26, 2009
Seller: Gidae Yeo
Added to Appulo.us: Sep 27, 2009
Latest version: 1.0.0
Battery Tracer provides a convenient way to monitor battery status and consumption over a range of activities.
With a quick glance, you can check the estimated time remaining for:
- For iPhone 3GS / 3G
* Talk (3G/2G)
* Standby
* Internet via 3G
* Internet via Wi-fi
* Video
* Audio
- For iPod
* Video
* Audio
Battery Tracer allows you to determine the percentage of actual battery usage for various activities. Want to know whether an hour of web browsing uses more battery consumption than 45 minutes of playing DOOM? Simply monitor both activities and compare the hourly percentages. An easy-to-use interface allows you to track, record, and label the elapsed time.
Going on a long plane trip?
Don't find yourself staring at a dark screen!
Battery Tracer can help you know whether you have the time to watch "Dances With Wolves" or if you should stick to an old Seinfeld rerun!
Battery Tracer is the most versatile and customizable battery monitor. Unlike other battery applications, Battery Tracer allows you to monitor and record the specific applications you use!
Chúc các bạn thành công và vui vẻ!!!
Nếu thấy hay thì nhấn DOWNLOAD các bạn nhé !
Battery Tracer
Category: Utilities
Price: $0.99
Seller: Gidae Yeo
* Talk (3G/2G)
* Standby
* Internet via 3G
* Video
* Audio
- For iPod
* Video
* Audio
