BLACKSTONE - PDAVIET ROM WM6.5 (Core 23554) Manila 2.5.2012
TranMinhMan
PDAVIET ROM WM 6.5 CE OS 5.2.23554 Build 23554.5.5.0
By TranMinhMan
*** Only for HTC Blackstone ***
Đặc biệt cảm ơn - Special thanks to:
Man PhamQuang
PV Award Sonblack
Hình ảnh ROM - ROM Images:
Thông tin bản ROM - ROM Informations:
- CE OS 5.2.23554 Build 23554.5.5.0 PV.
- Dựa trên nền Rom Ship mới nhất của BlackStone 1.59.841.5
- Base on the latest BlackStone Rom Ship 1.59.841.5.
- Tích hợp phần lớn các OEM mới nhất từ Rom Ship HTC Leo 2.10.531.0, HTC Rhodium, HTC Topaz.
- Plug in almost the latest OEM from Rom Ship HTC Leo 2.10.531.0, HTC Rhodium, HTC Topaz.
- Pagepool 17Mb
- Manila 2.5_20121412_1
- NetCF 3.7.8345.00
- Office Mobile 2010 v14.0000.23554
- NeoS2007_Driverpack_3
- Advanced Configuration Tool v3.3.0.0 by Julien Schapman
- ClearTemp v1_3 by Vicott Wong
- ChangeScreen v2.78 (config sensor autorotate screen)
- Co0kie_HomeTab_v1_6_1 by Co0kieMonster
- dotFred Task Manager
- e-Natives WM6.5.x Position Fix
- G-Watch_0_6_4 by ageye
- HTCPedia HD Settings Tool by Tom_codon
- htcAddicts cleanRAM v2.1 by ronenpg
- Opera Mobile 10 Final
- PIM Backup v2.8.0.0 by FdcSoft
- PocketNotepad v4.0.10 by Tilanosoft
- PocketRAR v3_93
- PocketScreen v1.3 by JJM. Roseboom
- Slide2Shutdown v1.1 by Cythrelo
- Synchro Time v0.95 by Dennis Grachov
- Total Commander CE v2.52 beta 2 by Christian Ghisler
- X2 Taskmanager WM 6_5_3 - v2
- WM 7 Titanium Project by Ibrythill (config your TitaniumWeather Location here )
- amarullzGreenBlack theme.
- m_carroll PureBlack3 Installer (W)VGA
- WMP12 WVGA skin by BOGYSOFT
- Some small games.
Link download đã được cập nhật!
Download link was available!
[DOWNLOAD]http://www.4shared.com/file/253469910/fc086e9d/BLACKSTONE_-_PDAVIET_ROM_WM65_.html[/DOWNLOAD]
[PASS]TranMinhMan[/PASS]
AnhPheCT
Đang đợi bản ROM này lâu lắm rồi! (Bản trước chưa ưng ý lắm)! Cảm ơn Adv Mod T2M nhiều lắm!! Download đầu tiên luôn!! Tối vào Cơ quan Up!! 15:58
====> Up xong rồi!! Cảm nhận đầu tiên quá đẹp! Có Calls History ở Today! Rất đẹp HTC Sense Adv Mod T2M build bản này đầy đủ! có 48 shortcut trên Today luôn!! Nó chung... Rất cảm ơn!! 17:50
Feedback====> Bản ROM này ko chạy được phần mềm VietMaps R12, ko biết tại sao luôn!! Khi mở VietMaps R12 lên vào Menu bị treo luôn, đã HR mấy lần nhưng vẫn ko sử dụng được! 23:50
htchd1
==> bản này đúng là có nhanh mượt hơn bản trước. nhưng cũng ngốn ram và còn chậm. mình có 1 em touch diamond 2 chạy 6.5.5 , manila 2.5 (rom của xda) chạy mượt kinh hoàng.
các bạn thử quay video độ nhanh và mượt của máy mình lên thử xem. mình có cảm giác như rom cho touch HD ngày càng chậm và nặng. còn đẹp thì tất nhiên đẹp rùi.
thank 2M
TranMinhMan
[/CENTER]
HD thì a nên dùng bản VietMap V17 dành cho WVGA (bản R12 đã cũ dành cho QVGA), e đang dùng bản này bình thường. Như đã nói ở các bản trước, nếu bật chế độ autorotate screen thì máy sẽ tốn ram và rất chậm (nó chiếm tài nguyên ram khoảng > 10mb). Vì vậy khi dùng thì thường do cách dùng nữa a àh (config sao cho hợp lý, khi bật tất cả hiệu ứng lên thì dĩ nhiên với lượng ram của HD sẽ khó mà đáp ứng nhanh nổi, ko treo là may rùi!), mà các ctr e plugin vào Rom hiện tại phần lớn dành cho Leo, mà cấu hình Leo thì a biết rùi! Nhưng e vẫn sẽ cố gắng đưa những gì hay và mới nhất vào HD, nếu nó còn đáp ứng được. Vì đã vọc thì phải vọc cho sướng!:D
TranMinhMan
thank 2M
Mọi so sánh chỉ là khập khiễng thui bạn, bạn phải hiểu cấu trúc nền như thế nào!? Ở các bản trước mình cũng sàn lọc các ctr sao cho chạy nhanh rùi, nhưng càng ngày càng có nhiều cái hay, đẹp nên mình bỏ thêm vào để ae cùng cảm nhận (đây là Rom cook mà), muốn vậy thì phải chấp nhận tốn tài nguyên ram => sẽ chậm.
Cảm giác mượt của bạn khi so sánh HD và Diamond2 dựa trên yếu tố nào bạn biết ko!?
- Diamond2 ra sau HD, độ tương thích các ctr gần đây sẽ tốt hơn HD. Kit Diamond2 dựa trên nền WM6.5 thật sự, còn HD bạn có thấy ra Rom Ship mới nữa ko!? Vì vậy Kit HD dựa trên cơ sở WM6.1 giả lập lên WM6.5 thôi.
- Cảm ứng Diamond2 mượt hơn HD.
- Danh sách các ctr hiệu ứng gây tốn Ram trên Rom của mình:
+ WM6.5.x (Core 235xx) sẽ tốn ram hơn WM6.5 truyền thống (Core 218xx)
+ Tiatanium giả lập WM7.
+ Manila 2.5
+ Sensor autorotate screen...
Nhưng đối với mình nó vẫn chấp nhận được và vẫn chạy tốt trên HD nếu biết cách dùng hợp lý, vì vậy mình vẫn plugin chúng vào.
Chúc vui!:D
AnhPheCT
Cảm Ơn Adv Mod T2M để tắt "autorotate screen" xem sao!! Bản sao cạp nhật GoogleMaps v4.0 (EN) chạy hay hơn GoogleMaps v3.21 (VN). Bản này quá đẹp vọc sướng rùi!! VietMaps chỉ ít khi dùng thôi!!
kimung
Sao trong tab menu của window media cứ hiện liên tục không tắt được. Phải reset sao????
AnhPheCT
Bản Rom này thật sự không ổn lắm rồi!! Tắt luôn "Autorotate screen" tắt HTC Sense chỉ còn màm hình Today bình thường ko mở Theme Titanium "Windows Default" luôn RAM gàn cả 100MB mà vẫn bị, Mở 1 chương trình không tài nào thoát Menu mặc dù chương trình đó đã thoát hẳn trong Task Manager như hình: Phải Reset máy lại mới hết. Potay rồi!! Chia tay bản này rồi!! Mặc dù nó đẹp nhất từ trước đến giờ!! Tuy rằng trong thư mục Windows\ còn rất nhiều Icon của phiên bản củ trước đó. Mặc dù đã là Icon mới nhưng khi tạo shortcut ra màn hình today HTC sense Icon củ của phiên bản trước đó!
Chia tay bản này rồi! Mong chờ bản tiếp theo thôi!​
htchd1
thank mod T2M đã góp ý. em cũng đang build 23551 manila 2.5.2012. bước đầu tương đối khá thành công. rom đã chạy.
em cũng thử nghiệm 1 số kinh nghiệm giải quyết vấn đề đồ họa. không biết mod đã thử chưa.
với manila có thể nén các file đồ họa xxxxxxx_manila xuống đến 40-60% dung lượng bằng CFC compréss. hậu quả sau đó làm manila hoạt động mượt mà hơn 15 - 25%.
với toàn bộ *.png (khoảng gần 1500 file Dung lượng gần 35MB. Nén = pngoutwin cho phép tiết kiệm đến 1/3 dung lượng và cải thiện xử lý đồ họa và tiễt kiệm ram đến hơn 20%.
Đối với *.bmp gần đến 1000 file (đặc biệt là bmp nằm trong *.dll như phonecavas , tapres192.dll) dùng paint.net để giảm bitrate xuống 8bit. Cho phép tiết kiệm đến 40-50% dung lượng và cải thiện đồ họa đến 20-30%.
Ngoài ra sẽ rất khác khi xóa hàng loạt file nhạc chuông, nhạc, tut, help, không xài đến (dung lượng gần đến 10MB)
Hy vọng mod sẽ thử nghiệm các vấn đề trên. Hoặc em sẽ chia sẽ toàn bộ file em đã xử lý cho bản rom này cho mod test thử.
Hix. Tại vì em vẫn chưa build rom hoàn chỉnh được vì lí do thu thập ext và oem mới quá lâu. Hy vọng mod chia sẽ kitchen cho em bản rom này để em đở nhọc công đi tìm.
htchd1
Em xin đính chính lại 1 tí là bản rom này có đến >2745 file png. Chiếm gần 35MB dung lượng. Sau khi nén = pngoutwin chỉ còn 18MB.
818 file .bmp = 42MB ( 300file bmp resouse in .dll gần = 8Mb) sau khi nén chỉ còn 20-25MB.
Với manila và .png. Hình ảnh và chất lượng sau khi nén 100% không thay đổi
Với .bmp thì có lẻ chất lượng ảnh thấp hơn 1 tí. Nhưng se không fát hiện = mắt thường. Nếu mod quan tâm. Tí nữa em sẽ up lên 2745 file png đã qua xử lý cho mod test thử. Mong mod quan tâm
AnhPheCT
Bản Rom này còn rất nhiều file *.png của các Bản Rom trước nên số lượng file tăng lên đáng kể.!!................!! Lại có 1 KTV nửa rùi à!!?? Waitting.......................!
htchd1
Con số >2745 file png đó là chính xác vì có thêm nhiều icon mới được tích hợp vào.
Pác anhphe thử nghĩ xem. Nếu tiết kiệm 15MB từ png + 20MB .bmp + khoảng hơn 15 MB từ xxxxxxx_manila = 60MB có ít đâu. Con số này em dựa trên bản trước của T2M. Còn số liệu chính xác thì hơn nữa vì bản rom này có tòi ra thêm nhiều chú
TranMinhMan
Mình ko rõ kỹ thuật nén của bạn như thế nào, có loading được file lên ko (cụ thê khi nén các file trong Manila có lên ko), hiện tại Manila 2.5 (kể cả 2.1) còn gọi là Sense đều là các package đóng gói các file hình ảnh. Bạn hãy thử build xem, nếu với những điều bạn nói và bạn vọc được thì với Kitchen trên diễn đàn bạn sẽ build được thôi!
htchd1
Sau đây mình xin trình bày các kỷ thuật nén đó. và câu hỏi nén manila 2.1 hay 2.5 có chạy được hay ko. mình xin trả lời: không những chạy được mà còn nâng cao hiệu suất của manila. (xin vui lòng tham khảo ở đây: http://forum.xda-developers.com/showthread.php?t=470798 )
Ở phần trên mình đã nêu ra 3 vấn đề (manila, png, bmp)
***MANILA***
Như mình giới thiệu ở link trên, phần tìm hiểu cơ chế hoạt động nén như thế nào và có đảm bảo chạy được không thì yên tâm. Mình xin hướng dẫn cách nén OEM của manila trước khi đưa vào rom
Đây là manila 2.5.2012 trước khi nén
Và đây là sau khi nén.
(hình ảnh sau khi nén có tăng lên 16 file là do mình chạy build rom sau nên nó tòi ra 16 file skip dung lượng 0Kb - chứ không phải mình copy thêm file vào đâu nha)
sử dụng CFC GUI như thế nào? (mình chỉ xin nêu ra 1 ví dụ (manila core thôi nha) qua bước này các bạn sẽ biết phải làm như thế nào đối với các phần còn lại)
khi khởi động lần đầu tiên. Chương trình sẽ muốn bạn dẫn đến thư mục chứa manila (ở đây mình dẫn đến thư mục manila core)(các bạn nhớ xem dung lượng của thư mục này trước khi nén và sau khi nén để xem thay đổi như thế nào)
Tiếp đó cửa sổ làm việc của chương trình hiện lên bạn chọn tất cả các file và nén chúng theo hình hướng dẫn
(trên đó là hướng dẫn nén manila. Hình ảnh và hướng dẫn chỉ mang tính chất minh họa. Các bạn sẽ phải nghiên cứu thêm ở link xda đầu tiên mình giới thiệu để đảm bảo manila hoạt động)
***PNG***
Xin giới thiệu công cụ PNGoutWin 1.01. để tìm hiểu cách thức và hiệu suất làm việc của chương trình xin vui lòng vào google. mình chỉ giới thiệu đây là một chương trình nén PNG cho phép giảm dung lượng nhưng vẫn giử nguyên chât lượng ảnh. đồng thời không những làm ảnh hưởng đến xử lý đồ họa mà còn rất tốt cho (ối viết dài quá chả biết viết j nữa)
Lần đầu tiên chạy các bạn cần thiết lập một chút. và theo mình các bạn nên làm theo hướng dẫn sau để sau khi nén file được nén được đưa ra ở một thư mục nào đó. việc xem xét, so sánh và thay thế bạn chỉ việc copy file được nén để thay thế vào.
Sau đây là ví dụ minh họa (mình dump bản rom 23547 - bản trước của T2M) và tìm tất cả các file .png trong rom ( tổng cộng có 2775 file) có dung lượng tương đương khoảng ~35MB
Để nén hàng loạt đống file đó. bạn chỉ việc Ctrl+A sau đó kéo thả và giao diện làm việc của Pngoutwin (nếu chưa đăng kí chương trình. bạn chỉ được phép xử lý 30file 1 lần dùng). nó sẽ tự động nén cho bạn
sau khi nén đóng file trên đó. Bạn còn 18MB. >< Tương đương bao nhiêu phần trăm bản gốc đồng thời giảm bớt công đoạn xử lý đồ họa cho GPU
***BMP****
Tiếp theo là file bmp. mình cũng xin lấy ví dụ bản rom trước của T2M. có tổng cộng là 818 file.bmp = 42MB. Sau khi nén bằng paint.net sẽ còn 20MB.
Sau đây mình xin lấy ví dụ một file .bmp lớn nhất trong bản rom 23549 để thực hiện nén
Và sau khi nén (408Kb ==> 204KB)
Về vấn đề BMP. Thực sự mình chưa test thử trên máy vì chưa có thời gian. Mod cứ thử làm 1 file này rồi đè vào máy xem hiệu quả thế nào. với 818 file cần xử lý. chúng ta tiết kiệm và hổ trợ GPU một liều thuốc bổ đáng kể.
Nếu các vấn đề mình nêu ra từ đầu mod thấy bổ ích thì xin Mod chia sẽ kitchen để mình đở bớt công việc. vì mình không thể vừa build rom vừa tìm kiếm OEM cho phù hợp.
Các phần mềm trên đều miển phí. trừ pngoutwin. lát nữa. để chỉnh sữa bài lại cho đẹp mắt mình sẽ up các tools đó lên. mong mod quan tâm vấn đề này và test thử >>> cùng chia sẽ kinh nghiệm với nhau để cho một tuoch HD tốc độ làm việc ngang ngữa HD2. hehe
(bài viết nếu thấy có ích cho các box cook và build rom khác. cứ copy paster thoải mái. không cần thank. chỉ cần trao đổi kinh nghiệm với nhau hết mình là uka)
NhatToai
hix, bài viết chưa đủ sức thuyết phục hay những j mình nói trên này là nhảm nhí sao ko ai có ý kiến j vậy ta?
thê thảm quá. có lẻ nên dọn sạch chổ này trả lại không khí trong sạch đẹp của thớt...
Cũng cần phải có thời gian cho cooker chứ bạn ;;)
Ngoài ra,bạn có thể lập riêng một Thread trong khu vực chung của dòng HD để cùng nhau thảo luận và chia sẻ kinh nghiệm về vấn đề này,như vậy sẽ tiện và hiệu quả hơn.
htchd1
ừh nhả. thế mà em chả nghĩ ra. nhưng mà dù sao fải chờ mod kiểm duyệt qua đã. nếu bây giờ những j em nói chưa được xác nhận đúng thì đưa ra topic riêng e còn sóng gió hơn nữa. em đang đợi phản hồi từ T2M.
có bước đệm này em mới dám póst ra kia đồng thời mở rộng performance graphic cho exe, dll,...
khổ 1 chiều nữa là em là thành viên mới. viết bài còn lộn xộn... cứ tạm thời háo hức chờ kiểm duyệt xong xuôi em sẽ đi tặng 1 bõx 1 bộ TUT cho nhoặng xí ngầu lên lun
NhatToai
Thành viên mới hay cũ gì cũng vậy bạn à,mọi đóng góp đều đáng trân trọng.
Mỗi người đều có sở trường cũng như sở thích riêng,vì vậy khả năng cứ đóng góp theo những gì cá nhân mình có ;;)
Mình gợi ý cho bạn lập thread riêng vì 2 lý do chính:
1- Chủ đề độc lập,thảo luận chia sẻ chuyên sâu hơn.
2- Topic ROM thì chỉ bàn đến vấn đề ưu khuyết trên chính bản ROM ấy,nếu để chung thì chủ đề bị chuyển hướng,sai nội quy và khó theo dõi cũng như tiếp nhận ý kiến về ROM ;;)
Chỉ cần bạn làm điều hay thì ngại gì phải chờ ai kiểm chứng =D>
Theo mình biết thì hiện tại AMod TranMinhMan đang khá bận rộn việc riêng nên rất ít thời gian để vọc ROM.
AnhPheCT
Mình có Up thử 1 bản ROM bên XDA chức năng thay hình nền Manila HTC Sense thì nó thay cho tấc cả các tab, Xin hỏi Rom của T2M khi thay chỉ có tab Today thôi! Làm sao để thay ảnh cho tấc cả các Tab? Cảm ơn!
lycucu
Rom ok lắm bác! bữa nào rãnh bác cho ra 1 Rom gọi là rom sạch đi! ví dụ như : rom với giao diện cực đẹp , nhưng loại bỏ bớt những phần mềm mà người Việt không sử dụng đến ! nếu bác ở tphcm thì khi nào bác rãnh em xin mời bác cafe rùi bác dạy em cách build Rom với! đọc trên web hướng dẫn bị hạn chế nhiều quá và ko có thầy dạy nên cũng hơi khó khăn
