azerty250776
![000d299e_medium.gif](http://pixhost.ws/avaxhome/9e/29/000d299e_medium.gif)
For those who aren't aware of the Bloons phenomenom, it's a simple target game where you pick an angle and power for a monkey to through a dart into a pile of balloons. Each level will have a quota to hit before you can move onto the next level. There are a limited number of darts for each level and some of them can get quite challenging.
The controls work quite well on the touch screen. Simply drag a line anywhere on the screen and it will be replicated near the monkey. Release your finger to fire the dart. It's a careful game of judgment where the slightest change in angle or power can have a big difference on the trajectory. It can be a little tricky getting the exact line you want but thankfully, the game plays very quickly with minimal loading times and replaying failed levels is rapid.
dl:
http://rapidshare.com/files/237692804/bipody.zip
http://www.uploading.com/files/XYNLJ1D5/bipody.zip.html
http://hotfile.com/dl/4006978/c48eb5a/bipody.zip.html
