file exe up quá PC nhé, ROM good, bản build này từ core 23016 mới hơn của helloword1
trích dẫn: GLOSSYX1
TRY AT YOUR OWN RISK
For ATOM/ATOM PURE ONLY
This is my second ROMs build 23016 with no big difference from others COM2 builds. It's very stable, clean and almost base function works as well.
Remove apps:
Windows Live
Marketplace
PhoneConsole
WMWidget
Adobe Flash
Add PersianBlue as requested, JBlend, NetworkWizard, FIX RAM management.
Big thanks to HelloWorld, SonBlack, TJ's, dolphinxda, vincentshjuan and all atom tester.
Download http://www.mediafire.com/?gznudtm13n5
Upgrade instruction:
Download and execute downloaded file, if something goes wrong, extract it and copy all files to C:\Windows\temp.
If you already running wm61 or wm65 go for OS+ExtendedROM, for wm5 user go for ALL option.
This ROM preinstalled with PersianBlue2.1 wich use lot of memory. Try to uninstall PersianBlue and you will save about 3MB memory.
Say thanks to bro GLOSSYX1 for this nice ROM
trích dẫn: GLOSSYX1
Remove apps:
Windows Live
Marketplace
PhoneConsole
WMWidget
Adobe Flash
