gily4ever
*#06# mã IMEI
*#0000# hay *#9999# mã version của máy
*#2820# mã bluetooth device address
*#7370925538#
*#Res0Wallet# xóa mã code wallet
*#7370# format máy(toàn bộ cài đặt trong máy)
*#7780# khôi phục cài đặt gốc
nếu muốn xóa logo thi c:/system/Apps/phone/oplogo và xóa đi hoặc chèn hình dạng .bmp là ngon ngay nhưng chú ý là cỡ ảnh là 97 x 25 là tối đa nhé
#pw+1234567890+1# kiểm tra tình trạng khóa máy
#pw+1234567890+2# Network Lock Status
#pw+1234567890+3# Country Lock Status
#pw+1234567890+4# SIM Card Lock Status
*#147# This lets you know who called you last
*#1471# Last call
*#21# This phone code allows you to check the number that "All Calls" are diverted
*#2640# Displays phone security code in use
*#30# Lets you see the private number
*#43# Allows you to check the "Call Waiting" status of your cell phone.
*#61# Allows you to check the number that "On No Reply" calls are diverted to
*#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to
*#67# Allows you to check the number that "On Busy Calls" are diverted to
*#67705646# Phone code that removes operator logo on 3310 & 3330
*#73# Reset phone timers and game scores
*#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible
*#7760# Manufactures code
*#7780# Restore factory settings
*#8110# Software version for the nokia 8110
*#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again
*#94870345123456789# Deactivate the PWM-Mem
**21*number# Turn on "All Calls" diverting to the phone number entered
**61*number# Turn on "No Reply" diverting to the phone number entered
**67*number# Turn on "On Busy" diverting to the phone number entered
12345 This is the default security code
press and hold # Lets you switch between lines
vì thời gian quá ngắ ko dịch hết mong anh em thông cảm
*#7370925538#
*#1471# Last call
