Nguyên văn tiếng Anh:
now, let us begin:
EXIT PC Suite. Very Important.
Installation part:
1. extract all archives downloaded.
2. install msxml6_x86.msi
3. install vcredist_x86.exe
4. install Nokia Connectivity Cable Driver.msi
5. install Nokia Flashing Cable Driver.msi
6. install Nokia Service Tool Drivers.msi
7. install Phoenix Service Software 2008 4.7..etc.msi (do not start it)
8. install phoenixreg.exe
9. install Phoenix_2006_2008_patch.exe (run it, click patch, you will get three messages : first one click no, second click no, third, overwrite.)
10. install Phoenix_Browser.exe (it is in Russian, just click next-next)
11. install Phoenix_To_Internal.exe (also next-next-next )
Now, run Phoenix ( PC Suite should be closed, or nothing will work. Make sure it is not in system tray(near the clock)
-in Phoenix, click "settings" button, on right side of connection.
-click add
-from driver tab, select USB, than click ok, and then ok.
-from connections tab, select USB.
-connect your phone, without SIM and SD card in pc suite mode.
-go to file - scan product. -> your menu will change.
-from operating mode select local. -> your phone will reboot, going into local mode. (it may give an error. Don’t worry, just select local again, until no error appears)
-now, go to product - phone browser.
-close the window that appeared
-go to my computer
-enter Phoenix Phone Browser
-now you have access to all directories. everything is accessible to you.
NOTE THAT YOU CAN NOT COPY ENTIRE FOLDERS WITH PHOENIX PHONE BROWSER. YOU WILL HAVE TO CREATE THE FOLDERS MANUALLY, AND COPY THE FILES INTO THE FOLDERS.
-after copying all you have to copy, select normal instead of local from phoenix software and you are done.
Now you can insert the SIM and Memory card again
Bắt đầu:
Bạn phải tắt PC Suite trên PC trước.Điều đó rất quan trọng
Cài đặt lần lượt các File sau:
2. install msxml6_x86.msi (nằm trong thư mục phoenix 2008)
3. install vcredist_x86.exe (thư mục ngoài)
4. install Nokia Connectivity Cable Driver.msi (nằm trong thư mục phoenix 2008)
5. install Nokia Flashing Cable Driver.msi (nằm trong thư mục phoenix 2008)
6. install Nokia Service Tool Drivers.msi (nằm trong thư mục phoenix 2008)
7. install Phoenix Service Software 2008 4.7..etc.msi (cài xong, đừng mở lên) (thư mục ngoài)
8. install phoenixreg.exe (thư mục ngoài)
9. install Phoenix_2006_2008_patch.exe (cài đặt nó, click vào patch, bạn sẽ nhận dc tin thông báo: thứ 1 click no, thứ 2 click no, thứ 3, cài đè overwrite.)
10. install Phoenix_Browser.exe (tiếng Nga, chọn next-next thôi)
11. install Phoenix_To_Internal.exe (tiếng Nga, chọn next-next thôi)
Bây giờ chạy Phoenix, nhớ tắt PC, nếu chưa kiểm tra nó trên khay hệ thống trên thanh Taskbar.
-Trong Phoenix, chọn "settings" button, ở phía bên trái chữ Connection.
-Chọn Add
-Khung Driver Tab, chọn USB, chọn ok, chọn ok.
-Từ tab Connections, chọn USB.
-Kết nối điện thoại của bạn vào máy, bỏ SIM và thẻ nhớ ra, khởi động lại máy chọn chế độ PC Suite
-Mở Phoenix -chọn File (bên trái) kéo xuống, chọn scan product. -> Nhìn phía dưới, sẽ thông báo về FW của điện thoại bạn đang dùng.
-Trên thanh Operating Mode chọn Local. -> điện thoại của bạn sẽ khởi động lại,(màn hình chớp sáng liên tục) vẫn chọn Local. (nếu nó xuất hiện lỗi.Bạn đừng lo lắng, cố gắng chọn Local lần nữa, cho đến khi hết lỗi xãy rar.)
-Chọn Product Tab- chọn Phone Browser.
-Đúng cửa sổ Window đó lại
-Chọn My Computer
-Chọn Phoenix Phone Browser
-Bây giờ bạn có thể thâm nhập tất cả thư mục của máy. Mọi thứ bạn có thể sử dụng dc.
Chú ý: Bạn không thể Copy toàn bộ Thư Mục với Phoenix Browser. Bạn phải tạo một thư mục khác, và COPY các File đến thư mục đó.
Sau khi Copy xong, chọn chế độ Normal thay vì Local từ Phoenix. Coi như bạn đã hoàn thành.
Bây giờ chỉ việc gắn SIM VÀ thẻ nhớ là xong.
Kết luận: Sau khi down hơn 120MB từ Rapidshare, tưởng có thể Hack ngon lành,ai ngờ kết quả ngược lại.Cái này dùng Phoenix để xâm nhập thư mục C:\Sys\Bin (có thể thấy dc, xâm nhập dc). Nhưng kết quả muốn chép File installserver.exe (file để Hack FW vào, thì nó không cho Paste)...
Đã thử rất nhiều lần, nhưng kết quả vẫn vậy. Nhờ mọi người thử xem...Chẳng lẽ đi đường vòng rồi cuối cùng chỉ xem dc C:\Sys rồi thôi.
Dòng này không rỏ ràng:
NOTE THAT YOU CAN NOT COPY ENTIRE FOLDERS WITH PHOENIX PHONE BROWSER. YOU WILL HAVE TO CREATE THE FOLDERS MANUALLY, AND COPY THE FILES INTO THE FOLDERS. -after copying all you have to copy, select normal instead of local from phoenix software and you are done.
(Không biết tác giả có dấu nghề không)= Làm đến bước này không cope file vào C:\Sys\bin được. Tạo thư mục khác, nhưng không rõ ràng, thư mục này tạo nên nằm chổ nào, rồi copy ra sau, nói chung chung quá.
Vài điều cùng các bác.Mong các Pro tham khảo thêm.
