Cảnh báo itunes 9.1.0!
Mình thấy mấy diễn đàn nước ngoài đang đưa ra thông báo là hok dc update itunes lên version mới nhất (9.1.0)
Theo như trên diẽn đàn IH8SNOW team nói thì:
* Update: It seems that blackra1n issues are occurring for Windows users only, Mac OS X doesn’t seem to have such issues. Should still wait for word.
* Update 2: Got a quick fix that will fix iTunes 9.1 issues with blackra1n (Windows). Will require a few hours to code. Stay tuned
Nghĩa là nếu update lên 9.1.0 thì blackrain khi unlock sẻ bị lỗi đối với Windows!Còn hiện tại bên Mac vẫn chưa có biểu hiện gì!Có diễn đàn nói rằng Apple sẽ khóa SHSH downgrade cho iPhone phiên bản kế tiếp nếu update lên itunes 9.1.0!
Còn đây là nguyên văn trên đó nói
“My guess is that in future versions of iTunes, Apple will probably handle the TSS request/response and later this year implement the code to process the response in the actual bootrom of the device. Here’s what I mean:
The newer iTunes versions will send a certificate request in the TSS request by adding a new key to the TSS request.
Their TSS server will create a new certificate with an effective date attached to it. (Making it invalid if used after that date) Until the new bootrom rolls out, iTunes will handle the decrypting of the response blobs using the nifty new signed certificate response ala APTicket.
Once Apple ships new devices with the bootrom capable of validating the new APTicket (or whatever they call it in the future) they can add logic to check the bootrom of the device and conditionally process the response from the TSS server(for old bootroms) or allow the device to process it(for new bootroms).
Looking at the above, it’s a fairly bullet-proof means of stopping local restores. Since the APTicket will be signed and likely shsh’ed I wouldn’t be surprised if they load APTicket or something like unto it BEFORE the LLB is loaded. This way they can not only control what VERSION of the firmware you install, they can also control WHEN you can install it by a means with far longer and sharper teeth.
If they implement the above, the only means of restoring will be via jailbroken device.”
Mình tham khảo ở nhìu nguồn và trong đó nguồn chính là VNmagic!Nay đưa lên để anh em PDAViet cùng thảo luận và đưa ra ý kiến có nên update hay chờ fix rồi hãy update!
