[cập nhật] UCWEB-7.6.0.75-beta,trình duyệt Web-Wap(VN-Server)
phuonxinh
Test Focus: various operations, a variety of interface interactions, animations, refresh rate (including the forward and back, and show the efficiency of web page), single-line text input box to support expansion of the input layer (5th edition is no such function, and only a single line more than half of the screen Intelligent input box will expand)
Functional development and optimization:
1.GUI major transformation, optimization of the internal logic of the code, and support for animation effects and fades; (this issue is only a small amount of animation, subsequent versions will be more hyun)
2. Adding animation forward and back
3. Offprints text input box to support the expansion of the input layer, a line can be turned into four lines.
4. Support the transfer length of connection: communication with theserver traffic faster and cheaper.
5.V5 skin transformation (changes too, is no longer compatible with earlier versions of the skin, temporarily use the default skin, thank you)
6. V5 business support drop-down field, enter the user no longer need to turn the two center screen.
7. Domestic third-party browser, take the lead float layout (which can be compared Sina 3G version of the weather page)
8. URL input window and search window optimization. (The first round of closed beta release only a small amount of optimization, the second round of closed beta next week will release a greater optimization)
Download http://www.mediafire.com/?k20b1fp917ey7w3
Mobile Download http://www.sharemobile.ro/file.php?id=585039
phuonxinh
cách sắp xếp trang, có thay đổi .hjệu ứng lật trang khá hay.mình phát hiện 1lỗi khi tiến hành tải file
satthumuhn
Xin hỏi các bác
em lên trang chủ ucweb.com mới có bản 7.4 VI
các bác kiếm đâu ra 7.6 VI beta vậy???
phuonxinh
lỗi này ko ảnh hưởng gj đâu.a e chỉ găp phải nó nếu để cài đặt đổi tên va chọn nơi lưu tệp khi download thôi. nó bị thiếu nút xác nhận khi chọn thư mục lưu. mình vẫn đang dùng nó mà
