[CFW] Hegazy Ultimate N97 V6.0 Rm-505 v22.0.110 All Language Supported The Fastest
Các pác xem link Youtube nha no screenshots
[video=youtube;PXwuAV2GfP4]http://www.youtube.com/watch?v=PXwuAV2GfP4&feature=player_embedded[/video]
Change Log For v6.0 :
1- Moved Browser Cache To E: Again For More Smoother And Performance.
2- Fixed Driver Cache Mod
3- Removed All Built In App .
4- Used The Original Themes And Used Simple And Unique Style..
5-Add N8 Icons And Re Order Menu
6- More C Space 65MB
7- Now Our CFW The First That Can Complete Support Installing Qt Applications And Run It Successfully As You r Using Original FW.
8- Camera Mod Now Pics Size More Than 1 MB
9- Add My Key Lock And Swipe To Unlock
10- Enhanced UI Mod Working So Fast
11- Integrated PIPS 1.7
12- Integrated 7Zip To Extract .7Z Files and also .rar plugin is installed by default
13- Add ApiBridge 1.1
15- Disabled StartUp Light For More Bettary Life Saver
16- Auto Lock Touch Screen Set to 30 Sec By Defult
17- Brightness Is Set to The Lower Lever For More Bettary Life
18- Increasing Auto Rotate Sensor Rsponse
19- Prevent UnNessesry App From Start Uo To Get More Ram Space
20- Voice Command Is Completley Disabled But You Can Start It Manually To Gain More Ram.
21- Audio Plugins Is Set With High Codecs.
Rompatcher+ v2.3 Embarrassed
Remove Recorder Tone Auto On
Open4all+ Auto On Must Be Disabled Before Using RamBlow To Prevent Phone From Restarting
Read CRoot Disabled
C2Z Disabled
C2zBin Disabled
Disable Red Light For Videos And Images Disabled
Active Bass Effects Disabled
BlueTooth Locker Disabled
- All Patches Tested And Working Prefectly
Application You Get With Hegazy Ultimate N97 v6.0:-
1- WinRar Plugin v1.0 ( Built In SoftWare Can't Be Deleted )
2- RamBlow V1.0 Fully Working Cracked Without Any Bugz And Can Be Updated And Removing If You Wish ( Not Built In SoftWare Can Be Deleted )
3- Kill Me To Show Open Process And App And Terminating What You Want Can Be Updated And Deleted If You Want .
4- NsysInfo Gets Every Possible Information About Your Great N97 Device. ( Built In SoftWare Can't Be Deleted )
5- Adope PDF Is Cracked For Ever (Unlimited Trial Period)
6- Nokia Notification Widget For Home Screen Show Your Message And Missed Calls
7- Conversation App Make Your Messages Like Iphone.
FEATURED:
- Remote Lock still enabled
- Voice Command still Disabled
- Nokia OVI Welcome (My Nokia) Disabled
MODS:
SYSTEM CACHING AND PERFORMANCE:-
- Fonts Version Updated (Replaced by C6 fonts).
- Running application will cache in All Drivers For Better Berformance
- RAM totally Optimise at startup
- Some Apps totally disabled on startup
- Improved Increases system memory heap size
- Decreases application delay and close time taken by apps
- Improved UI Acceleration .
- Improved Rotation Speed.
- Improved Scrolling Speed With Fixed Menu Lag
- Disabled Speed Scrolling In Short Lists
- Improved Camera Photos (Disabled Compresstion Of Photoa You Got About 2M For Photo But It's Worth)
- Improved Video Capture .
- Improved Video Call Quality.
- Browser cache moved to E:\
- Max fps increased from 22 to 28.
- Prevented apps to run in background (messaging,log,contacts,...).
- Improved WiFi sensivity.
- Dictionary Arabic Language.
Call:
- Summry After Call Set On By Defult
- Show Call Duration Set On By Defult
AUTO MAKE/COPY FOLDERS:
- E:\thinkchange\c
- E:\thinkchange\e
- E:\Music
- E:\patches (auto copy patch)
- E:\Recevied
- E:\system\Cache
PATCHES:
Read CRoot Disabled
C2Z Disabled
C2zBin Disabled
PERSONALISATION:
- Shutdownscreen : Hegazy Bios Ultimate ShutDown
- Splashscreen : Hegazy Bios Ultimate StartUp
- Bootscreen: Hegazy Boot Screen
- Shutdown image removed for faster shutdown
- Alarm Snooze interval is set to 7min by default
- Light Intensity set to 50% light by default
- Theme Effects: Swip And Rotate Full And Working Smoothly
INSTALLATION:
- SwiPolicy changed which enable to install almost apps without installserver patch
- Remove annoying widget security during installation of sis, sisx
- Secure Widget Preinstall will not run on first startup.
- Java permission is Set To Always Allowed
- Install Server.exe Installing Any App Without Certification (No Error In Certification ) By Defult Even If All Patches Disabled
BlueTooth:
Press 0 To Switch On / Off Bluetooth ( Built In SoftWare Can't Be Deleted ) Have Fun With That.
SECURITY:
- Automatic lock phone in 30 seconds by default
- Auto Dim Screen Light After 15 seconds by default
- Maximum automatic lock phone can be set up to 10 minutes
- Flash Player Working Correctly
MENU AND SENSORS:
- Tapping Mode added: shake to get phone silent/snooze alarm .
CONNECTIVITY AND BROWSER:
- Nokia Default Internet Browser can go landscape with turning control OFF
- Auto Resume Download manager will be started on browser start-up to resume
- Nokia default file browser can send sisx, sis, jar and any protected items via bluetooth, mms and uploads
- Nokia default file browser will open private, sys, C: root folder
- FOTA reserved spaces in C: deleted: gain 5MB
- Bookmark Edited And Deleted
MESSAGING, CONTACTS AND HIDDEN APPS:
- Message to My Nokia will not send on startup
- Delivery reports set to on by default
- No. of message sent saved increase from 20 to 999 by default
- Ovi Contacts totally disabled
CAMERA:
- Camera sound is disabled In Photos When Choosing Camera Sound No.1 ( Defult ) Even If Warning Sound Set To On
- Video Recording Tones Is Completely Disabled (Start/Pause/Stop)
- Camera will not leave in background after close it (SAVE RAM)
VOICE RECORDING AND VOLUME:
- All automatically set to the highest quality
- Now you can record up to 12 Hours
- Internal speaker automatically set to maximum when calling
- Loudspeaker automatically set to normal 10/10
- Bootscreen volume slowed: Normal volume
- Voice recording during call fixed
MUSIC PLAYER AND GALLERY:
- Put all songs file in E:\Music and F:\Music
- Music player only read E:\Music and F:\Music location
- Faster to refresh
- Gallery Improved to find files
Ringtones Embarrassed
N8 & C6 Defult Ring Tones And Also Add To Genral With Defult Message Tone For N8 Also By Defult
Change All Alarm Tones To Nuclear Alarm Tone By Defult
you can find them in profile settings
OVERVIEWS FOR NOKIA N97
- RAM after reboot: 62 mb
- RAM after clean up: 61 mb
- C: drive space after reboot: 65 mb - RAM experinces may different due to language in rofs2
MUST!!!!! READ THIS NOTICES BEFORE DOWNLOAD!!! DO NOT IGNORING THIS!!!
1) Hard reset needed to avoid conflict of homescreen and apps installed
2) Format MMC is recommended or just delete E:\private E:\sys E:\system E:\resource E:\patches and F:\private F:\sys F:\system F:\resource F:\patches
3) Delete Any _PAIbTN Folder For Images In E:\Images F:\Images
4) Please Leave Your Phone 7 Min After Flashing Or Hard Reset.
Read CRoot Disabled
C2Z Disabled
C2zBin Disabled
FEATURED:
MODS:
Call:
- E:\thinkchange\c
- E:\thinkchange\e
- E:\Music
- E:\Recevied
- E:\system\Cache
PATCHES:
Read CRoot Disabled
C2Z Disabled
C2zBin Disabled
PERSONALISATION:
INSTALLATION:
BlueTooth:
SECURITY:
MENU AND SENSORS:
CAMERA:
- Faster to refresh
DOWNLOAD
http://www.multiupload.com/1PE0195RZR
