Color Keyboard HD 0.9.3 - Đổi màu, đặt hình nền keyboard cho iPad
AquaSta
Nếu trên iPhone, iPod touch có Color Keyboard thì đây là Color Keyboard HD bản dành cho iPad, nó giúp bạn thay đổi màu sắc bàn phím, đặt hình nền và thay đổi hình nền cho bàn phím. Ngoài ra nó còn cho phép bạn thay đổi góc bo tròn cạnh của phím trên bàn phím. Yêu cầu iPad sử dụng iOS 4.0 trở lên
DESCRIPTION:
Requires iOS 4.0 or higher
Compatible only with iPad
Colorize keyboard on you iPad.
Now, you can change colors of key buttons or add background image.
Includes support for keyboards in iPhone-mode apps (classic apps)
After installation,
Launch setting app > Tap "Color Keyboard" > Tap "Select Themes" > ( Select theme which you want. ) > Tap back button > Tap "Save" button which is placed at top right corner.
Read here to
make your own theme
Themes folder is /Library/ColorKeyboard/Themes/
No new icons are added to your homescreen. You can configure options from your Settings app.
See larger Screenshots below
VERSION:
v 0.9.3
* Added plugin features.
* Enhanced Phat's themes
* Fixed bugs
v 0.9.2
* Added about 40 themes.
* Supported split-keyboard in iOS5.
* Localization (Hebrew)
[NOTE] To activate this go to Settings app > Color Keyboard. You need to be connected via WiFi or 3G for your license to be downloaded.
DOWNLOAD:
v 0.9.3
http://www.mirrorcreator.com/files/09LRXZKS/
http://www.mediafire.com/?df3ber6jacb970k
v 0.9.2
http://www.mirrorcreator.com/files/1ZXZUJII/
http://www.mediafire.com/?k88b9fmp4hap615
