nguyenpa
Hiện tại mình đang dùng bản CorePlayer v1.2.5 built 4506 S60v3 cho N91.
CorePlayer™ Mobile is at the center of the CoreCodec™ Universe for manipulating multimedia content on your desktop, mobile phone, portable media player, PDA, GPS, or convergence device. CorePlayer is designed to be a next-generation multimedia platform that will extend upon what you thought were limits in playing back fluid multimedia, with its simple yet extremely powerful interface and features that is designed to empower the CoreCodec Community.
See why companies like Joost are using CorePlayer technology and why the Chicago Suntimes times says that, "it actually has a user interface designed with bipeds in mind."
Technology Bullet points
* Built-In YouTube Support
* Bluetooth ready!* (A2DP and AVRCP)
* Podcast, Enhanced Podcast, CoreCaster Ready
* GPU support: Intel 2700g, ATI Imageon, QTv, Marvell Monahan Processors (more coming soon!)
Operating System Support: Symbian (all), CE (3.x - 4.x), Windows Mobile/Smartphone (5.x - 6.x), Palm. (Linux for OEM only)
* CPU Support: ARM9, ARM11, MIPS
CoreUI 'Universal skins' Widget. Allows you to create a unique custom user interface exactly how you want it!
Best in Class audio and video codecs like CoreAVC our High Definition H.264 video decoder
CoreTheque media library allows for easy management of your playlists and bookmarks
Hiện tại dùng coreplayer xem video flash (*.flv) online rất vô tư, embetube và mobitubia N91 ko dùng được
Nhưng gặp vấn đề là ko thể downloads files video về máy được. Có ai biết cach thì hướng dẫn với.
