TruongHan
Giống game lắc xí ngầu của samsung,Dice rolling là 1 game nhỏ 3D cảm biến chuyển động (3D acceleration and motion sensors)
Trang chủ : http://www.creabros.fi/cms/index.php?id=29
![10.png](http://www.creabros.fi/cms/images/10.png)
Settings:
try the settings out, I set them to fairly reasonable values, range of the values is pretty much between 0 – 1.0. No checking for bad values is done so it is possible to get division by zero or something strange. Values are not stored, so restarting the application will reset everything.
Application keeps running in the foreground and doesn’t let the light go out so it will drain battery if left on top. It should be ok in the background, but I haven’t made any measurements.
[YOUTUBE]http://www.youtube.com/watch?v=HZfbwt_6ML4&feature=player_embedded[/YOUTUBE]
