Download iOS 5.1.1 Firmware For iPhone, iPad And iPod Touch
sonhoang1606
On March 7, 2012 Apple released iOS 5.1 for iPhone, iPad and iPod touch. This major update was released soon after Apple had made the official New iPad announcement. Since then an update to iOS 5.1 has been anticipated, particularly because jailbreakers were able to have their way with iOS 5.1. Apple fixes vulnerabilities that jailbreakers use in it’s firmware updates.
The release notes of iOS 5.1.1 firmware for iPhone, iPad and iPod touch are quite detailed. Here’s what’s new in iOS 5.1.1:
This update contains improvements and bug fixes, including:
1. Improves reliability of using HDR option for photos taken using the Lock Screen shortcut
2. Addresses bugs that could prevent the new iPad from switching between 2G and 3G networks
3. Fixes bugs that affected AirPlay video playback in some circumstances
4. Improved reliability for syncing Safari bookmarks and Reading List
5. Fixes an issue where ‘Unable to purchase’ alert could be displayed after successful purchase
The release notes are quite self explanatory and don’t require further paraphrasing. Obviously it is imperative that you upgrade your supported iOS devices to iOS 5.1.1 so as to fix critical bugs and get security and performance enhancements. This update carries build number 9B206. If you go ahead and download right now, do keep in mind that Apple’s servers will be slammed with immense amounts of traffic, which will result in slower download speeds. So if you want a swift download, it’s always best to wait for at least a day before installing a new iOS firmware version.
There are two methods that you can use in order to install iOS 5.1.1 on your iPhone, iPad or iPod touch. You can plug in your device to the computer, launch iTunes and click Download and Install when iTunes prompts you that iOS 5.1.1 is available for your particular device. Alternatively, you can manually download iOS 5.1.1 ipsw for your respective device from the links given down below and do a manual firmware restore on your device using iTunes.
Official iOS 5.1.1 Firmware Download Links:
iPhone 3GS http://appldnld.apple.com/iOS5.1.1/041-4347.20120427.o2yov/iPhone2,1_5.1.1_9B206_Restore.ipsw
iPhone 4 GSM http://appldnld.apple.com/iOS5.1.1/041-4293.20120427.3DRyb/iPhone3,1_5.1.1_9B206_Restore.ipsw
iPhone 4 CDMA http://appldnld.apple.com/iOS5.1.1/041-4291.20120427.Zs8F0/iPhone3,3_5.1.1_9B206_Restore.ipsw
iPhone 4S http://appldnld.apple.com/iOS5.1.1/041-4346.20120427.1RuDG/iPhone4,1_5.1.1_9B206_Restore.ipsw
Original iPad http://appldnld.apple.com/iOS5.1.1/041-4292.02120427.Tkk0d/iPad1,1_5.1.1_9B206_Restore.ipsw
iPad 2 http://appldnld.apple.com/iOS5.1.1/041-4294.20120427.Pp5qM/iPad2,1_5.1.1_9B206_Restore.ipsw
iPad 2 AT&T http://appldnld.apple.com/iOS5.1.1/041-4296.20120427.dPX6x/iPad2,2_5.1.1_9B206_Restore.ipsw
iPad 2 Verizon http://appldnld.apple.com/iOS5.1.1/041-4297.20120427.NAvbf/iPad2,3_5.1.1_9B206_Restore.ipsw
iPad 2,4 http://appldnld.apple.com/iOS5.1.1/041-4295.20120427.8nB8U/iPad2,4_5.1.1_9B206_Restore.ipsw
3rd Generation iPod Touch http://appldnld.apple.com/iOS5.1.1/041-4300.20120427.WvgGq/iPod3,1_5.1.1_9B206_Restore.ipsw
4th Generation iPod Touch http://appldnld.apple.com/iOS5.1.1/041-4298.20120427.Tzr8w/iPod4,1_5.1.1_9B206_Restore.ipsw
New iPad Wi-Fi Only http://appldnld.apple.com/iOS5.1.1/041-4327.20120427.xW6U6/iPad3,1_5.1.1_9B206_Restore.ipsw
New iPad AT&T http://appldnld.apple.com/iOS5.1.1/041-4328.20120427.1sCra/iPad3,2_5.1.1_9B206_Restore.ipsw
New iPad Verizon http://appldnld.apple.com/iOS5.1.1/041-4329.20120427.LTkro/iPad3,3_5.1.1_9B206_Restore.ipsw
ducthang
Bản cập nhật này chứa các cải tiến và sửa lỗi, bao gồm:
  • Cải thiện độ tin cậy của việc sử dụng tùy chọn HDR cho ảnh được chụp bằng phím tắt trên Màn hình Khóa
  • Giải quyết các lỗi có thể ngăn iPad mới chuyển đổi giữa mạng 2G và 3G
  • Sửa các lỗi ảnh hưởng đến việc phát lại video qua AirPlay trong một số trường hợp
  • Cải thiện độ tin cậy cho việc đồng bộ hóa dấu trang Safari và Danh sách Đọc
  • Khắc phục sự cố trong đó cảnh báo 'Không thể mua' có thể hiển thị sau khi mua thành công
