nblong21
Bản Rom Wm6.5+Manilla v2.5,trước mình đã từng dùng thử Dutty's HD WM6.5 Leo R1 Test thấy cũng oki,chỉ co FootPrint la chưa dùng dc
Description:
Password = Duttys HD WM6.5 Leo R2 Release
Dutty's HD WM6.5 Leo R2 Test Change log
· Change to MS Build 5.2.23016
· Updated with new HTC LEO ROM
· Updated Applications and Drivers, these are some listed below.
· Updated HTC Audio Manager
· Updated HTC Email Setup Wizard
· Updated HTC Keyboard version V2.1 now with fixed space bar.
· Updated HTC New Contact Card
· Updated HTC Streaming Media
· Updated HTC Volume Control
· Updated HTC Lock screen App which you can now customise and set your own lock screen wallpaper through manila settings
· Added Opera in R2 although its not default in Manila.
· This is a new Leo Rom and I only port it over 90% exactly as the Original Rom with some fixes and some enhancements.
· Some minor fixes and amendments from Leo R1
· The new R2 feels much more solid and stable only issue I seen is that in the manila home screen the date refreshes 2 different times and then show right time within 2 seconds, apart from that its been my main Rom now
Things to know , some minor issues, bugs and workarounds Leo R2 Observations
· This is a test a ROM and some bugs will be there as manila 2.5 is not finish yet.
· After flashing Rom please hard reset.
· If you use New Contact card and use face book to log in, at first log in, your picture will not show, workaround just click on new contact card and click face book and it will add your picture.
· If Connection setup doesn't auto start first time after first boot just soft reset or do it manual in connections.
· The new HTC Setup wizard is now fixed with Sim password input but its a bit slower this time.
· New Manila 2.5 uses its own HTC Messaging application which is now fixed for me without any issues found last few days
· New Manila 2.5 uses internet Explorer as default in Manila in Leo Rom.
· Been using the Rom for over a week and its stable and can be use daily with the minor bugs mentioned above.
· New manila now support landscape mode automatically in music and album tabs.
· I had to use HTC Leo Phone canvas which doesn't support video calling because my current phone canvas doesn't work well with manila 2.5
Screen Shots:
Description:
Screen Shots:
