PhamHien
* Sơ bộ:
Bản ROM mới nhất vừa được giới thiệu bởi tác giả NRG28 bên xda. Đây là bản RC1 (release candidate 1), được làm dựa trên nền tảng của dòng máy mới nhất: Snap
* Trích dẫn
"The XIP (kernel) and SYS (main system files) are directly ported from HTC newest handset, the Snap. The drivers are ported from the HTC's latest official released ROM (the "brightpoint rom").
*Một số hình ảnh ROM
* link: đang up lại...
* Hướng dẫn up ROM:
1. Run Auto.bat included in the archive. It should resent a black command prompt window.
2. Make sure you remove your storage card from the phone before the next steps.
3 .Follow the instructions in the black window. Do NOT reboot when the SDA unlocker tells you to reboot the phone. It's not necessary.
4. You might get a prompt asking you if you want to run the spl program. Just say yes. At that point you should get a white screen.
5. If for any reason you're not seeing a white screen, you did something wrong and you need to try again.
6. Flash the ROM following the instructions in the flashing utility.
You can expect the phone to be "stuck" on the green windows mobile screen for about 2 1/2 minutes the first time. After that, it should only take about 40-45 seconds for the phone to reboot.
* Trích dẫn
* Hướng dẫn up ROM:
