Eset Mobile Security Beta - Soft diệt virus nổi tiếng đã có trên Symbian
jinsk8r
Bản này mình đã post trên v5 nhưng v3 xài tốt nên share qua đây cho ae xài ^^
(Lần đầu post bài bên v3)
Eset Mobile Security Beta for Symbian (s60v3/v5)
New Features
  • Anti-Theft features, including SIM Matching and Remote Wipe
  • SIM Matching enables users to define a list of trusted SIM cards on a certain device
  • Remote wipe allows users to remotely delete sensitive information using a pre-defined password and SMS command
  • Fully integrated firewall monitors ingoing and outgoing communication in accordance with user-defined rules and profiles
  • MMS/SMS anti-spam includes black/whitelisting and blocks unwanted messages
  • Security audit checks phone features relevant to mobile security and notifies the user of security concerns
  • Remote Administration support in the Business Edition
Improvements
  • Heuristics have been optimized for use on mobile platforms
  • Infected files can be placed in a Quarantine folder, from which the user can then choose to restore or permanently delete them
  • On-Demand scanning scans the entire device or specific folders
  • Advanced On-Access scanning scans all created, used or incoming files
  • Logs and statistics are in a more accessible format
  • The user interface has been enhanced to promote ease of use with settings dialogs and an intuitive menu
Beta Considerations and Requirements
The beta test version is a precursor of the final product without full functionality and documentation. It is intended for experienced users and should not be installed on operating systems or devices that perform critical tasks because it may cause errors or crashes.
The ESET Mobile Security Public Beta 1 software runs on Symbian S60 3rd Edition Feature Pack 1 or 2, Symbian S60 5th Edition and Windows Mobile versions 5.0, 6.0, 6.1 and 6.5.
Tải tại đây (hoặc tại đây - nhấp vào link Download dưới cùng)
Cách đăng ký (đây là bản beta nên đăng ký miễn phí)
Các bạn vào trang http://beta.eset.com/mobile
Sau đó nhấp vào More Info (bên phải ngoài cùng), điền Email và mã xác nhận, Eset sẽ gửi Username và Password để kích hoạt vào địa chỉ email của bạn.
hakudo2408
Siu nhưn cook fw bên v5 qua đây post bài, chuyện lâu năm mới thấy ;))
mà eset này thì liệu có an toàn như kas ko nhỉ??
jinsk8r
^^ siu nhưn gì đâu bạn
Cái này của ESET mới ra mắt beta ngày 22/4 thôi chờ review của mấy trang web bảo mật xem sao ^^
Không chạy trên N73
N73 mà cài pm Virus làm gì, nặng máy\-/ Đến con Lap của em mà còn chẳng cần nữa là.:p
Mới đi Ghost lại PC của một nạn nhân chuyên cài Virus trên PC, cuối cùng bị chương trình Virus mà hắn cài phá cho hỏng máy>:)>:)>:)
anhchanbonmat
N73 của mình từ hồi đó tới giờ cũng không xài những thứ này
. chẳng qua cài vô cho biết kết quả test được trên máy nào thôi
Mình test trên N95 chạy được :p nó cũng là v3 nên post thôi :p N73 thì ko có máy test
Down bình thường mà bạn. Direct link đó.
bạn có thể cho list cài được trên máy nào hôn
Bo0Bo0
Từ ngày dính quả Kis mobile em cạch dùng các loại phần mềm diệt virus cho mobie
Ram thì thoải mái nhưng dùng bị 1 số vấn đề
