ETEN (Glofiish) X600 WM6.1 V05M (Manila2D) - Build 20764.1.4.3 (NEW)
ROM V05M (Manila2D) CHO ETEN X600
=== CE OS 5.2.20764 Build 20764.1.4.3 ===
Phiên bản V05M, WM6.1 ROM có tích hợp chức năng Manila2D giao diện đen trắng dành cho ETEN (Glofiish) X600, với các đặc điểm chính:
- Dựa trên nền tảng OEM của phiên bản ROM WM6.0 mới nhất của X600: bản 0411.
- Tích hợp chức năng Manila2D đen trắng được sưu tầm từ các KTV trên WiKi.
- OS với Core-20764 Aku-1.4.3 được port từ Ship ROM của Touch HD
ROM chạy ổn định sau khi Up, các chức năng hoạt động bình thường.
LINK TẢI ROM V05M (X600):
* RapidShare:
http://rapidshare.com/files/186982819/ETEN_X600_WM6.1_V05_M2D_B20764.rar
[I]Pass.: [COLOR="Silver"]PhamQuang[/COLOR][/I]
erickwill
Hello Friend!!
Thanks for your great work and for remember us!
Congratulations!!!
Erick Will
dancer_69
Thanks for your great rom=D>
How much memory is available? Cause manilla takes a lot of space.
erickwill
Hello Friend,
Yes I love your roms! It's ever stable and pretty cool!
Is there a way to cook a rom with manila 2d but using the HTC clock version (last X600 rom version) and the last cool background that you had used on the last version of X600 rom?
Thanks once more!
Cheers,
Erick Will
Hello Friend,
Thanks once more!
Cheers,
Erick Will
Yes, you can change anything you like. :D
erickwill
Hello Friend,
May you help me to do that? Please... :D
Come, friend.. give me a help.. please.. :-??
Cheers,
Erick Will
erickwill
Hey friend..
May you cook a rom with this beta version for us, enthusiasts of WM news?
Come friend.. please.. do it for us, our rom fans!
cheers,
Erick
wpgoalkeeper
Hello my friend!!!!! And thank you very very much for this rom!!!!!! Great job!!! But... I have one problem. I have the bluetooth headset iTech (for 2 phones). When I connect my phone and make one phonecall, everything is ok. But if I want to call someone again or someone is calling me, I must disconnect the bluetooth of my device and connected again because I can not listen anything (or make a restart)... Is there anyone who has the same problem as me?? Can I fix this problem with a .cab??? I didn't have this problem in your previous versions. I don't want to delete this rom because I think is better than the previous ones. Thank you very very much!!!!
kopa
Thank you very much for preparing such a rom. And had a great visual device. :) But rest mode after the device keypad is active. Work success. Sorry for my English. (Greetings from Turkey)
a_simplenick
Sau vài hôm dùng bản rom này, em xin có vài ý kiến sau:
- Nhạc chuông tự động set về mặc định, lại phải set lại (thường xuyên).
- Không có GPS Viewer kèm theo ext rom, bỏ qua thế mạnh của Eten. Mặc dù cài thêm sau cũng được, nhưng nếu lấy soft của eten add vào thì chắc là hay hơn. Phím tắt GPS không gán được cho ứng dụng khác.
- Giao diện M2D chạy khá ốn, mượt, nhưng ram còn hơi ít. Khi chạy thêm ứng dụng hơi nặng chút, như VietMap hoặc Opera 9.5 thì hay treo, phản ứng chậm, trước khi dùng toàn phải tắt M2D.
- Xét về tổng thể thì em thấy vẫn khá ổn vì giao diện đẹp, chạy không ứng dụng thì không có gì phải bàn. Em đang tìm hiểu cách chỉnh sửa rom, ban đầu là thay đổi Extrom để tự build bản rom cho mình. Mong mọi người chỉ giáo thêm......
fouade
Bác Phạm Quang quá tuyệt, đang chờ ROM 6.5 cho x650. Hy vọng sẽ sớm có. Thanks
Tomsk_hp
Bác Quang ơi. Cháu đang chạy rom của bác, nhưng không hiểu sao máy hay bi treo, và thỉnh thoảng bị bệnh không nhận được thẻ nhớ. SR lại thì lại bt, sau một thời gian thì lại bị tiếp. Có phải do máy hay là do Rom hả bác. Có ai bị tương tự không, chỉ mình với nha. thanks!
hungdq3
* RapidShare:
ai gặp khó khăn khi down ở link trên thì down ở đây nhé
PHP:
http://rs336.rapidshare.com/files/186982819/ETEN_X600_WM6.1_V05_M2D_B20764.rar
phtnguyenchan
Bạn ơi! Mình mới có Eten X600 từ Mỹ gửi về, gắn sim vào sao không có sóng, mình chưa biết sử dụng nó. Bạn có thể hướng dẫn căn bản được không. Máy vẫn hoạt động được các chức năng khác như kết nối internet(WIFI), nhưng không thấy chức năng gọi phone, mặc dù nó vẫn nhận sim , đọc được danh bạ trong sim.
mong bạn nhiệt tình giúp đỡ, cám ơn nhiều lắm. Mấy ngày nay rảo trên mạng tìm hướng dẫn hoài không thấy.
Bạn có thể gửi qua mail: phtnguyenchan@gmail.com
Mình ở Sóc Trăng, ở sâu trong nữa(trong vườn)
