Fancy Widgets Pro v3.4.3 FULL 100%! (Cập nhật Skins )
BuuPhucCT
f-705-3
Đây là bản "Full" hoàn chỉnh PM thời tiết và đồng hồ đẹp mắt nhất trên android. Sau bao ngày chờ đợi đã có cao thủ "full" thành công PM cứng đầu này.
New version (v3.x) highlights :
★ All new widget designs
★ Additional widget styles
★ Better skin support
★ Access to the Fancy Widgets Market
★ Moon phase calculation
★ New widget sizes (1x1, 2x1, 4x1, 4x2, 4x4)
★ Choice of AccuWeather as your weather provider
★ Multiple ocation support for both clock and weather
ss-480-3-11
Basic Features :
  • Clock with customizable time and date format
  • Current weather condition and 3/4-day weather forecast
  • Celsius and Fahrenheit temperature support
  • Geo-location for weather or search city by name/zip code
  • Configurable refresh interval
  • Additional information (e.g., battery level) on the widget
  • Customizable widget tap actions
  • Automatic sunrise/sunset time calculation
  • Moon phase calendar
  • Different widget sizes and styles with skin support
  • Access to the Fancy Widgets Market and convenient skin management
  • Many customization options to make your beautiful widgets
Full Version Exclusive Features :
  • Multiple location support for both clock and weather
  • Choice of Google, WeatherBug or AccuWeather for weather forecast
  • Current temperature notification
  • Severe weather alerts with customizable notification options
  • Easy backup/restore of your widget settings
  • Over 400 clock and weather skins to decorate your home screen
  • Fancy weather animations (rain, storm, snow, etc.)
  • Fancy Widgets 1x1: weather icon, moon phase, date, battery
  • Fancy Widgets 2x1: forecast, digital/flip clock, date
  • Fancy Widgets 4x1: digital/flip home (clock and weather), weather, forecast, digital/flip clock
  • Fancy Widgets 4x2: digital/flip clock
  • Even more customization options
Changelog: What's in this version:
  • New: location alias. (full version only)
  • New: forecast animation duration. (full version only)
  • Added support for backup/restore of location settings. (full version only)
  • Improved support for Google Weather with geolocation.
  • Fixed some bugs with skin preview cache for the Fancy Widgets Market.
  • Added Catalan translation.
  • Updated language translations.
  • If you purchased Fancy Widget Pro before, please request your license key from our website to unlock the full version.
Info:
https://market.android.com/details?id=com.anddoes.fancywidgets&hl=en
http://www.multiupload.com/27IN8LUTD0
http://www.mediafire.com/?7fa2q8rdj658vjz
NOTE: Bạn nên gỡ bỏ tất cả những bản cũ đã cài đặt trước đó và cài bản này đảm bảo xài OK.
n3h1p5
- xin lỗi, cho mình hỏi mình down về cài rồi mà sao nó ko hiện lên màn hình vậy, mình phải chỉnh ở đâu các bạn, mình đang sài rom MIUI
- do đây là lần đầu tiên sài Android nên hơi gà, mong các bạn thông cảm
yeskia
Room MIUI đôi khi hơi kén ứng dụng của bên thứ ba.
Bạn thử khởi động lại máy xem.
Nếu vẫn không thấy, hãy vào ứng dụng nào có chức năng quản lý phần mềm, tìm xem có không. Nếu có bạn cho nó chạy, sau đó thoát ra xem có shortcut chưa. Nếu vẫn chưa thì hãy gỡ bỏ do không tương thích
venusian
Mình đã chép theo hướng dẫn, khi vào Appearance settings chon Clock skin thì chỉ thây skin mặc định thôi. Mong bạn giúp
Bạn down về giải nén ra nhé. Chép từng cái vào một.
Tạo thêm đường dẫn và chép cái Skin clock vào mới đc bạn nhé.
Android/data/fancywidgets/clockskins. Nếu chưa có thư mục clockskins thì bạn tạo mới và chép skin vào nhé.
quangeuro
rom MIUI xài tốt bạn, cái này là widget, bạn giữ ngón tay trên khoảng trống trên màn hình sẽ hiện ra cho bạn chon widget
venusian
Cập nhật Fancy Widgets Pro v3.5.4 Full Version
Có gì mới:
  • Hỗ trợ cho màn hình XHDPI (ví dụ, Galaxy Nexus)
  • Sửa lỗi với cập nhật giờ trên màn hình dự báo
  • Sửa lỗi vấn đề nhỏ với các cảnh báo thời tiết (chỉ có phiên bản đầy đủ)
  • Cải thiện cơ chế để có được thời gian báo thức tiếp theo
  • Cập nhật ngôn ngữ bản dịch
venusian
Cập nhật Fancy Widgets Full v3.5.5
Có gì mới:
  • Sửa lỗi FC khi cố gắng để mở khóa trên các thiết bị chạy Android 2.1 hoặc cũ hơn
  • Thay đổi tùy chọn báo cáo cho phép người dùng chọn không tham gia báo cáo.
