FastBall 1.2
phongisme02
FastBall 1.2
In FastBall, you control a rolling ball. In his way, there are many obstacles and his only ability is to jump. This is where he needs you, you'll make him jump by tapping the screen.
With this simple mechanic, FastBall contains 40 action packed levels. Through the levels, you'll need a good timing, pure attention as well as decisions on which path to follow to reach the level end.
It is easy to play and easy to enjoy.... What's new
- Fixed an OpenFeint related bug where after you open the dashboard, the gameplay becomes unresponsive and unplayable.
- In "Marathon" gameplay, HighScore is now saved even if you don't complete it.
http://hotfile.com/dl/39439398/393a9d0/FastBall__v1.2-AD.ipa.html
kidhack
FastBall 2 (update)
FastBall 2 (update)
Description
FastBall is back and is faster, fun and addictive than ever...
With this simple mechanic, FastBall 2 contains 85 action packed levels spawned across 2 level packs. Through the levels, you'll need a good timing, pure attention as well as decisions on which path to follow to reach the level end.
http://www.filedude.com/download/HZefHjPRo490b1535919
