Firewall iP - Bức Tường Lửa Cho IP!
Firewall iP is now available on CydiaStore for only $1.99.
Firewall iP allows you to block outgoing connections (TCP & UDP). It hooks into applications
from AppStore and Cydia. Firewall iP will alert you if the app wants to establish a connection to a host and shows you the hostname. Then you have the options to allow/deny the connection once/always or allow/deny all connections for the application.
You can decide if the application will send data. Developers will no longer be able to collect stats about you (UDID, phone number, usage statistics…) or even collect personal data. With Firewall iP you can cover all app analytic providers which aren’t in PrivaCy and also custom analytics.
You can block some content too. Now you are the one who decides!
In the control app you can edit the rules for each 3rd party application as well as add new applications to the list. It also offers a switch to disable Firewall iP and a SBSettingsToggle for the same purpose.
Apple’s native applications and Cydia itself are excluded for obvious reasons.
* Block outgoing TCP & UDP connections selectively
* Shows you the hostname for the connection
* Block analytic providers which PrivaCy can’t
* Block unneeded content
* Easy to use interface & control app
* Edit the rules you did set
* Add apps manually
* Low memory & CPU consumption
After installation and a respring it will start to monitor outgoing connections.
_______________________________________________________________
Firewall đầu tiên cho IP đã có mặt, chưa có thời gian thử nhiều nhưng được coi là khá hấp dẩn với những người dùng apps hay games xxx. Cho biết thêm ý kiến khi dùng các bạn nhé!
[DOWNLOAD]http://www.mediafire.com/?yz3m42m1my0[/DOWNLOAD]
Hướng dẩn cài đặt:
1. SSH vào iPhone theo đường dẩn /var/root/Media/Cydia/AutoInstall (Nếu không thấy các directory có tên Cydia và AutoInstall thì các bạn tự tạo lấy.)
2. Nhúng file .deb vào theo đường dẩn /var/root/Media/Cydia/AutoInstall.
3. Respring iPhone cũa bạn.
Thông tin thêm chi tiết tại đây.
* Add apps manually
Hướng dẩn cài đặt:
