Thangnd31082
GifTailor v2.0.0 S60v3 [Cập nhật 08/07/2010]
Tạo ảnh động GIF+Nhiều tính năng nổỉ trội
Phần mềm khá hay , đã có bản cập nhật mới với nhiều tính năng khác được support. anh em tạm tham khảo bản giới thiệu bằng Tiếng Anh trong lúc chờ mình dùng GG lược dịch nhé !
Gif Tailor allows you create cool glitter frame gif images with your own photos or screenshots on your handsets.
Tailor the use of GIF can easily create animated GIF files, with the following characteristics:
1, * support for screen shot
2, * to import jpg / gif / png / bmp / mbm picture
3, * to save a single picture to a jpg / gif / png / bmp / mbm files (you can achieve the image format conversion)
4, * adjust animation speed can be a unified, single frame can be adjusted
5, * can be very convenient to adjust the location of the frame all gif
6, * Support watermark, transparent color to pure white (255, 255, 255), can be used to support the picture as a watermark
7, * Support for touch screen, you can drag images to the designated location
8, * adjustable output image quality
9, * GIF picture can be split
List of shortcuts:
0 to delete all the pictures
1 position in the current insert picture
3 additional one picture to the last
4 forward a current picture location
5 Save the current selected picture
6 after the current picture of a position shift
* Set the current selected picture of the delay
Preview GIF animation OK.
What's new:
1. the additional screen video recording, capture period set by delay;
2. an additional cycle drawings function (regular drawings), capture cycle through the delay settings;
3. capture mode additional enhanced mode, ability to provide more drawings, etc. may crawl lyrics show display;
4. rewrite the GIF codec module, to read and write faster and generate smaller files to avoid using the system API exception when decoding problem;
5. add the GIF file, the file can be imported all the animation frames;
6. a transparent GIF file is saved as an additional function;
7. can be set drawings areas can be visualized orientation can also be entered manually;
8. an additional feature to set the temporary folder (cache path, D drive the fastest);
9. additional temporary file compression option (no compression, the default compression, fast compression, maximum compression);
10. rewrite the scaling algorithm, to avoid using the system API to scaling is slower, while addressing in some cases the problem can not work;
11. add the file, select multiple files and added progress display;
12. support the mbm file to import all the pictures;
13. split GIF file, additional progress bar, and resolved to be optimized GIF file shows the problem with incomplete;
14. can program settings for the system to avoid the memory automatically when the system is shut down;
15. additional delay unified set of all image features;
16. the additional functions to save all files;
17. the additional file name prefix editing;
18. additional drawings priority setting function, recommended setting for the high priority;
19. ICO and WMF files to read additional features;
20. the additional position of watermark set function;
21. the additional watermark transparency setting function;
22. support the MBM / PNG / ICO file itself transparent watermarking support effect;
23. solved the screen anyway can not be correct drawings after switching the bug;
24. settled into PNG image to display unusual problems;
25. the additional file number setting function.
