Giới thiệu và thảo luận về các bản MIUI GINGER 2.3
langthang262
Do topic giới thiệu về các bản MIUI cũ của bác Alcola66 đã quá dài và bác Alcola66 không còn cập nhật nữa và tuần này sẽ bắt đầu có bản MIUI based GINGER 2.3 nên mình lập topic mới để cập nhật và thảo luận về các bản MIUI.
"MIUI 1.3.11 released version of 17 points on time, please pay attention!
Note:
1. The first brush MIUI ROM, please be sure to select the wipe clear the data Recovery
2. After the upgrade by OTA or brush the full package without wipe, do not affect user data in mobile phones
Update:
Phone:
Time when no SIM card restoration of China belong to the default
If the incoming call log in the repair without number, the problem appears to be empty
Enable the proximity sensor repair, the phone call is answered can not be automatically lit black screen problem
Repair phone screen will not light up after hang up problem
SMS:
SMS collection logic optimization
Lock screen:
Lock screen repair can not click OK when the horizontal screen problems
Theme:
Add more pages to enter full screen mode, click Preview
Thumbnail will cover the repair wallpaper border problem
Details about top end repair sliding error resources
Heading the list of categories of resources error fixed
Optimization and global unified cache directory topics
Settings:
Add wallpaper wallpapers added to the options
Optimization settings in the ring setting and themes of the ring setting to get through
Music:
Added support for links to online MP3 Player (in text messaging, press a link, start the player)
New online music player automatically cache the next song
New player spectrum switch, by default, you can set off
Optimal rejection song CPU occupancy to reduce power consumption
Camera: (in MIUI network disk download)
Zoom slider fix the display of the camera do not support scaling, click on the zoom slider does not appear
Repair some models AF flash flashing problem
Effects model using the camera does not fix the entry into force BUG"
Link download bản gốc Tiếng Trung MIUI 11.3
http://bigota.d.miui.com/miui_HD2_1.3.11_2.2.zip
hatnaf
Không cập nhật cũng phải, giờ ngta đâu còn quan tâm nhiều đến MIUI nữa, trong khi các bản Desire HD nhất là các bản stock chạy ngon hơn nhiều. Ít lỗi và mượt, ram free cũng nhiều gần như MIUI mà còn có SENSE nữa, điều mà MIUI ko thể nào có. Nên nếu xét ra thì các bản HD ngon hơn chứ, vả lại sắp có 2.3 cho HD rồi còn gì.
ratmitdac
Nhưng cá nhân em thấy bản MIUI pin có vẻ ổn hơn. Dùng được có khi đến 2 ngày
langthang262
Mỗi người 1 quan điểm mà :)
Bên DHD cũng vẫn dùng MIUI chứ có phải chỉ dùng bản stock đâu.
Mỗi bản ROM đều có ưu điểm riêng, và người dùng có quyền thử và lựa chọn bản ROM phù hợp với mình.
Azzura
Mỗi người một quan điểm thôi :) Riêng mình mình đang chờ bản MIUI mới này, hi vọng em nó sẽ thật ngon ^^
hackbabe
Đúng là thay thế sense chỉ có thể là MIUI , nhẹ nhàng mà cũng đủ hiệu ứng, mình cũng cài khá nhiều bản rom HD, HDZ..... và cuối cùng thì vẫn quay về MIUI, thay pin khởi động lại cực nhanh, cảm ứng mượt mà, pin tốt, sử dụng đơn giản.
Mong chờ bản 2.3 để test.
langthang262
Tình hình là theo thông tin ban đầu trên Miui.com, có thể MIUI 2.3 sẽ không hỗ trợ HD2 và nhiều Model khác
"Since many people are guessing 2.3.3 is the starting model which is not added to new models, is that not all models are supported. Here give us some reference.
Many netizens MIUI very image of the characteristics of induction: MIUI only vest CM, CM to support any type, MIUI what models will be supported, CM can not do this, MIUI can not do this. It is true that, CM has the advantage of supporting multiple models, the ability to do transplants, MIUI is characterized by emphasis on user experience and close to the Chinese users, its ability do not have the break, just the two complement each other. As the level of increase is not enough energy is limited, MIUI models fit the current strategy is completely standards-based Android + CM + any other open source communities, and then do some small changes. MIUI all the achievements are based on the open source community selflessly, in the future we will see MIUI for community feedback.
MIUI future will focus on the user experience of all, rather than on the model fit. Therefore, if the CM does not yet support a model, MIUI is unable to do. This includes Defy, Music Phone, Meizu M9, Milestone2 other famous models. Therefore, seeking post messages here fit various models, it is better to apply to the CM forum.
This morning, CM's 2.3.3 transplant has been completed, but the stability of each model is not the same. MIUI will select the most stable side of priority releases. Members can also go swipe CM7 the ROM, since the stable recommended to us that, we will reference.
In addition, not all supported models MIUI CM support, this is because the energy is not enough. Will support the three conditions are met:
1. Resolution higher than 800x480, this is because the support would need to do two sets of low-resolution UI, to draw two sets of maps, is twice the workload of the powerless. Therefore, it is not supported G6, G8 does not support. Are the reasons for the resolution.
2. Forum than 1,000 registered users (tentative), the user too little, then, maintenance costs are relatively high. So now, did not support the possibility of Desire Z, but in the future will support the user more natural.
3. Google's mobile phone, no matter how much we will support the user, which is to drink from the source, to pay tribute to the Android, which involves Nexus One and Nexus S"
Azzura
Khi nào có hình ảnh của em nó bác update cho mọi người chiêm ngưỡng nhé ^^
langthang262
Trên miui-dev.com đang quyên góp tiền mua Nexus S cho Mod Mark để Mark tiếp tục mod MIUI cho mọi người.
Thấy bảo đóng góp được 270$/600$ rồi. Mình thấy đây cũng là một ý hay :), mọi người mỗi người đóng góp 1 chút để Mod ra các bản Rom hay cho anh em dùng, vì Mod cũng bỏ nhiều công sức mà
"Hey everyone,
I read in the forums that JohnnyBeGood started asking everyone to help pitch in to get Mark a Nexus S. I know Mark doesnt like the idea but it honestly thats too bad. :D I think everyone knows at this point, that without Mark MIUI wouldnt have come near as far as it has today. He has been translating and doing his modifications since Sept 30th of last year. That is almost 6 months he has dedicated every friday to making sure the Language Pack is properly put out for porters to create their ROMs from. He even takes his laptop to work to make sure that the community gets the pack as fast as humanly possible. That being said i know many of you have donated in the past, and we are very thankful for that, most if not all of that money has gone to creating, maintaining, and expanding the site into what we have today. With the newest news I’m sure you have all seen this weeks release will be MIUI 2.3 for the Nexus S. This really upset Mark as he has poured his heart into this just to see his device (Nexus One) get put on the back burner. This alone with some past drama has really pushed Mark away.
With all this being said I propose like JonnyBeGood did to start a donation box to help fund Marks new Nexus S, and keep MIUI alive. I have talked to Mark as against his better judgement has agreed to continue if I can raise enough money to get him the Nexus S. The goal is set at 600USD (to account for paypal fees + conversion rate to GBP) as Mark has to buy the phone Contract Free.
Now i know Mark doesnt feel right about this, and he thinks this is wrong, but honestly he has given so much to this community its time to give back to Mark.
So lets get this done and keep MIUI alive!"
langthang262
Thông tin mới nhất về MIUI Ginger 2.3.3:
Development team has been carrying out recently MIUI 2.3 upgrade, while also preparing another meal for everyone: the third edition of UI.
Part of the third edition of UI will be released along with the 2.3.3 version, it will fit in with the gradual improvement of 2.3.
The other is still a fixed bug, added some new media features:
Complete list, or other officially released on Friday."
nguyentri80
yehhhhh ...... vậy là mình sắp đc chiến rom típ rùi .... mà ko bít khi nào mới có bản cho HD2 ta
nnq_mm
sẽ có cho hd2 thôi, thiếu rom cho hd2 đồng nghĩa với 1 thiếu sót lớn
langthang262
MIUI Weather - Cập nhập mới chuẩn bị cho giao diện MIUI mới nào
Links:
http://www.miui-dev.com/miui-weather/
Azzura
Hôm nay là thứ 6 rồi, hi vọng sẽ có bản 2.3 đầu tiên ^^
Cuối tuần được thưởng thức em nó thì còn gì bằng :))
BboyRong
hic hồi hộp quá..hy vọng nó sẽ ngon hơn bản 2.2... chúc cả nhà HD2 ta đc thỏa mãn mong ước...
