Hard-SPL by OLINEX dành cho HTC Rhodium (TouchPro2)
nncuong
Administrator
Sau 1 thời gian chờ đợi, cuối cùng thì cộng đồng Rhodium cũng có thứ để thử nghiệm.
Man PhamQuang đã thử nghiệm mấy hôm nay ok rồi, đang cook rom mới. Hiện tại tôi đang thử up bản 6.5 ship, sau khi thành công sẽ đưa thông tin chi tiết lên.
Thông tin nguyên văn của tác giả
Hard-SPL Release Time!!!!
preface: okay, it was released only this weekend! but trust me the wait was worth it as it works really great and smooth now!
important: again, don't forget, it's like with topaz - each user gets 1 license, or perhaps 2-3 on request if needed (which is valid forever and all this works as transparently as possible, so won't be a problem at all), while businesses who need to unlock more devices than that, can pay, PM cmonex or Olipro if you want to discuss bulk unlocking.
you can also PM cmonex for requesting 1-2 more devices for private user (free).
Preparations
0) this package is for Rhodium (Touch Pro 2, not the original Touch Pro) devices. CDMA-GSM worldphone version is not accepted (RHOD400, RHOD500 modelids), that will have its own Hard-SPL later. this Hard-SPL supports WM6.5.
1) if you have Vista / Windows 7, WMDC update to 6.1 (or whatever is latest) is recommended: http://www.microsoft.com/windowsmobi...ce-center.mspx
Instructions
read this if unsure how to install Hard-SPL... if you are an experienced user and you just downloaded the HardSPL package and it worked, then cool. but if you are unsure or run into an issue, then you should read the following!
1) download newest Hard-SPL package from Rhodium-HardSPL_xxx.zip attachment, extract to an empty folder.
2) you must Have Phone Synced with PC in Windows Mobile!!! I mean it has to be connected to activesync or WMDC via USB cable. and it must not be in Flight/Airplane mode (i.e. radio should be on).
3) NEW: internet access is required as the program checks online for updates and license.
4) run Rhodium-HardSPL_V1_20R2.exe on PC, make sure it's launched from a local drive (not through network drive, etc.). XP requires Admin logon, and Vista/Windows 7 will automatically prompt to allow it to run in Admin mode, allow it please. if you get an antivirus warning, please ignore it, it contains no harmful code (just used a packer to compress it).
5) follow steps as prompted in the Hard-SPL program. if this is the first run of Hard-SPL on a device after hard reset, you must select Automatic flash mode (the first button in Welcome screen).
notes: you should usually go for Automatic flash mode; the Manual flash option is only to be used as noted below and you must only attempt the Manual mode option if Automatic flash mode or SSPL-Manual.exe already put device in black screen. any other errors triggered while running in Autoflash mode will have to be fixed as instructed in the error message.
6) it will ask you to wait while it prepares for the flashing, press OK.
7) now it should go through without any error messages, if one does pop up, then please follow the instructions included in the error text. if no specific instruction is shown, then ask for help in the thread, but this should not ever occur (as this means a really fatal error occurred).
8) at this point the device did hopefully went to a black screen (reporting version as 1.01.C-SSPL only using "info 7" in mtty), this is the SSPL version, which is temporary. then RUU will instantly launch.
9) some notes: when RUU says it will hard reset, do not worry, it is not going to do that. also when it says the flash will take 10 minutes, ignore that, it will only take a minute or so.
10) SPL flashes, device automatically reboots, job done.
11) to confirm you got it installed, go into bootloader mode (tricolour screen!) and verify the screen shows 0.85.OliNex, which is the Hard-SPL version.
NOTE: you will not see the SPL version during normal boot, that is the OS version, not SPL!
to enter SPL to check version, do a soft reset while holding the "volume down" key on the left side of the device. keep holding the volume down key until you see tricolour screen which is the bootloader mode, then release it.
NOTE 2: this is unsigned Hard-SPL. no limitations on flashing ROMs (except of course some Radio roms). also, this has overwrite protection against HTC RUU's overwriting HSPL with a stock one, so if someone needs to revert to stock SPL for warranty reasons, a stock SPL downgrade package is posted here below. use this relocker *only* if you need to return the phone for warranty, and only use it as last step - after reflashing stock OS and radio. see steps at the end of this post about how to reflash stock SPL.
NOTE 3: anyone having USB problems with the device after it entered SSPL mode, please copy SSPL-Manual-Rhodium.exe from SSPL-Manual-Rhodiumxxx.zip attachment in this post, copy it to the device and run it. then once the screen has gone black, run the Hard-SPL package on the PC and you must select Manual flash option. *important*: make sure that the USB cable is plugged in and device is synced to Windows Mobile even if doing manual method.
NOTE 4: do not use this RUU for anything other than SPL flashing (i.e. hardspl or stock spl restore)!!! nothing other than SPL's made by Olinex team (using OliNex custom cert, which is not public) will flash to make SSPL more secure. if you want to flash some other rom, then use shipped RUU or rhodium customRUU if you need to flash cooked ROM.
NOTE 5: for developers asking: Hard-SPL is not based on MFG SPL, as it can strictly be used for development and hacking, contact cmonex in PM if you need that one.
NOTE 6: supported OS versions: both 32-bit and 64-bit XP, Vista, Windows 7RC and later. win2000 was untested, and pre-RC win7 (lower than build 7100) is explicitly not supported. also, the program may be unstable or not work on Virtual systems, so it's recommended to try outside Virtual OS softwares. also, version verify: if Hard-SPL package says V120R in first Welcome dialog title (and version 1.20 in About box), it is the latest version, not some crappy beta/old version.
Troubleshooting and Step by Step on reflashing stock SPL are in next post below!
credits
first, "OliNex" is a team which means: cmonex + Olipro
Olipro -> concept of EXE program that runs on the PC, Hard-SPL concept, server-side license code and maintaining the licenses.
cmonex -> HSPL package on PC, SSPL loader for windows mobile and SSPL binary. Hard-SPL binary. (SSPL loader: partially based on haret and old pof&Olipro jumpspl code),
finally,
Mạng chán quá không attack lên được, các bạn tải về theo link www.phudongsoft.net/roms/Rhodium-HardSPL_V1_20R2_185HSPL.rar
PASS: pdaviet.net
CỤ THỂ CÁC BƯỚC CHẠY HardSPL​
Thực tế chạy HardSPL cho HTC TouchPro-2 khá đơn giản, nếu chuẩn bị và tuân thủ các bước sau đây:
1/ Cần chuẩn bị cho PC đã có cài ActiveSync 4.5 và NETCF. Tốt nhất nên tiến hành trên WinXP, sẽ an toàn hơn rất nhiều.
2/ Cho máy (TP2) kết nối và Sync hoàn chỉnh với PC (quả cầu xanh hết xoay).
3/ Tải HardSPL theo link trên về, tắt các trình kiểm tra Virus (nhất là Norton, nếu sử dụng) và giải nén, sẽ là 1 file exe: Rhodium-HardSPL_V1_20R2_185HSPL.exe
4/ Chạy Rhodium-HardSPL_V1_20R2_185HSPL.exe, sẽ đòi hỏi kết nối NET và sau vài giây sẽ hiển thị như quá trình Up ROM.
5/ Nếu hoàn thành, bạn đưa máy vào Bootloader sẽ thấy hiển thị như sau:
SPL: 0.85.OliNex
Thank to Cmonex !!!
yhanoi
máy mình rom 1.19.707.1(51489) Radio 3.44.25.27 Protocol version: 61.25t.25.19U xin hoỉ ae là có phải rom ship không và bản mình thuộc vùng nào?Nếu cho mình link rom ship 6.5 chính hãng thì xin mời cafe nếu bạn ở HÀ Nội
Nemmatlanh
ROM SHIP CHÍNH HÃNG CHƯA CÓ THÌ PHẢI BẠN Ạ,NHƯNG BẢN ROM 6.5 CỦA CHÚ QUANG BUILD DÙNG CŨNG NGON LÀNH LẮM,CHẠY RẤT MƯỢT,ROM CỦA BẠN ĐANG DÙNG CHÍNH XÁC LÀ ROM SHIP CỦA MÁY ĐÓ.BẠN CỨ NẠP HARD SPL VÀO MÀ UPROM DÙNG CHO SƯỚNG NHÉ :)
ruoicom
Em đã up, nó báo sucessfull... nhưng em lại ko chú ý đến bước này...
SPL: 0.85.OliNex
Nhưng chắc là OK ạ, lát em sẽ up rom 6.5 lên xem sao ạ.
tvtung
Em đã ngắt Norton (start up & service) nhưng vẫn không thể nào giải nén được file download. Các bác giúp upload dùm em file đã giải nén (.exe) được không ạ? Cám ơn các bác nhiều.
QuangThang89
Bạn klick chuột phải rồi chọn Extra thui, cái này có liên quan gì đến ctr diệt virus đâu :-?
Nemmatlanh
Link down vẫn bình thường bạn nhé,bạn down về rồi giải nén với pass là: "pdaviet.net" nhé.Chúc vui :)!
betheone123
Mình bị Error hoài thôi. Khi nó thông báo Ok and Wait mình Ok thì màn hình TP2 đen thui sau đó trên PC hiện lên thông báo như up rom và mình làm theo y chang nhưng sau đó báo là Error.
Cho mình hỏi cứ mỗi lần chọn Next đễ up rom thì TP2 tự shutdown làm mất kết nối với PC nên mình nghỉ đây là lí do làm Error. Có bạn nào biết help với. Màn hình tắt đen chứ ko chuyễn qua màn hình up rom
Thanks
iniuboo
anh ơi, sao em để flash nó ko tự động nhẩy, phải tự bật bootloader thì nó mới đc
mà được rồi thì đứng nguyên ở 0%, chả chạy tí nào là sao:(trời ơi, tại sao em ko thể chạy được nhở, làm mọi cách nó cứ đứng ở 0% cả nửa tiếng rồi báo backup
X-(
namy2k
Mình cũng bị lỗi y vậy, mà trước mình làm thủ 1 chú rùi rất ok sao giờ làm lại hoài mà không được
NguyenTu
X-(
HSPL cho TP2 cần có Internet nhé các bạn, Bạn kiểm truyền mạng. bảo đảm PC có kết nối Internet. Mình làm bình thường mà. Các bạn cứ làm theo hướng dẫn trên đây là OK.
blackpuck
Nếu tôi không nhầm thì olinex sẽ không cho phép bạn Hard SPL lần thứ 2 trên cùng 1 máy có cùng IP, lần thứ 2 trở đi sẽ không được phép làm mà phải liên hệ với bên olinex. Có ai gặp trường hợp như mình chưa. Khó quá mình toàn dùng máy ở cty qua server nên không thể làm lần thứ 2 được
sgking21
Thanks
X-(
Đúng rồi, mình dùng VNPT phải reset modem mấy lần để lấy được số IP mới thì mới có thể flash Hard SPL được, lúc trước cũng bị lỗi giống như các bạn ở trên
