HD2 T9193 tesla cần chỉ dẫn :)
MrBeOaRT
HD2 T9193 tesla <<<< em này có vẻ ít ng` dùng .
Các bro cho em hỏi
- em này có cần unlock ko ạ
- việc unlocking ram 576 dc ko
- việc úp radio khác gì các bản hd2 khác ko ạ
Tks
trinh12345
Trước tiên là khuyên bác khi up radio thì cẩn thận và đọc kỹ hướng dẫn nhé, ko thì thành cục gạch đấy. Em chỉ biết có thế:) còn T9193 tesla thì em cũng chả bít nó là cái j nữa, hihi.
hlp
GOOGLE cho bác nhé :
Detailed Technical Specifications of HTC HD2 T9193 Telstra (HTC Leo)
Brand: HTC
Browse HTC devices
Manufacturer: HTC
Browse all devices manufactured by HTC
Hardware:Designer: HTC
Project;Codename: HTC Leo
Browse all devices under HTC Leo codename
Release_Date: January, 2010
Physical_Attributes
Dimensions
(width x height x depth): 67 x 120.5 x 11 millimetres
2.6 x 4.7 x 0.4 inches
Bounding:Volume: 88.8 cubecentimetres
Mass: 157 grams (battery included)
Software_Environment
Embedded_Operating;System: Microsoft Windows Mobile 6.5 Professional
Browse devices running this OS
Operating:System_Kernel: Windows CE 5.2.2
Microprocessor,+Chipset
CPU;Clock: 1024 MHz
CPU: Qualcomm Snapdragon QSD8250
Browse devices based on Snapdragon QSD8250
Width+of-Machine-Word: 32 bit
CPU_Core: Qualcomm Scorpion
Instruction;Set: ARMv7
Memory,_Storage+capacity
RAM-type: mobile DDR SDRAM
RAM_capacity: 448 MiB
ROM_type: Flash EEPROM
ROM:capacity: 512 MiB
Graphical_subsystem
Display-Type: color transflective TFT display
Display:Color+Depth: 16 bit/pixel (65536 scales)
Display_Diagonal: 4.3 " (109 millimetres)
Display-Resolution: 480 x 800 (384000 pixels)
Viewable;Display+Size: 2.21 " x 3.68 " (56.08 x 93.47 millimetres)
Dot_Pitch: 217.4 pixel/inch (0.11683 millimetre/pixel)
Audio-Subsystem
Audio_Channel(s): stereo sound
Analog/Digital Converter
(Recording): 16 bit nominal quantization
44100 Hz sampling frequency
Digital/Analog Converter
(Playing): 16 bit resolution
44100 Hz holding frequency
Microphone(s): mono sound
Loudspeaker(s): stereo sound
Audio;Output: 3.5mm plug
Cellular-Phone
Cellular-Networks: GSM850, GSM900, GSM1800, GSM1900, UMTS850, UMTS2100
Cellular:Data+Links: CSD, GPRS, EDGE, UMTS, HSDPA, HSUPA
Cellular-Antenna: Internal antenna
Call+Alert: 40 -chord melody (polyphonic)
Vibrating_Alert: Supported
Speakerphone_: Supported
Phone_Controller: Qualcomm Snapdragon
Control;Peripherals
Positioning:Device: Multi-touch screen
Primary;Keyboard: Not supported
Directional-Pad: Not supported
Scroll+Wheel: Not supported
Interfaces
Expansion;Interfaces: microSD, microSDHC, TransFlash, SDIO
Supports High Capacity (SD 2.0/HC) memory cards with capacity of up to 32GB
USB: USB 2.0 client, Hi-Speed (480Mbit/s)
USB Series Micro-B (Micro-USB) connector
Bluetooth:(802.15): Bluetooth 2.1 + Enhanced Data Rate, Internal antenna
Wireless_LAN/Wi-Fi+(802.11): IEEE 802.11b, IEEE 802.11g, 54 Mbit/s
Internal antenna
Infrared:Gate: Not supported
Multimedia-Broadcast
Analog;Radio: FM radio (87.5-108MHz) with RDS radio reciever
Proprietary headset as antenna
Digital;Media-Broadcast: Not supported
Satellite:Navigation
Built-in_GPS_module: Supported
GPS:protocol: NMEA 0183
GPS-Antenna: Internal antenna
Complementary:GPS_Services: Assisted GPS, QuickGPS, Geotagging
Navigation_Chip(set): Qualcomm gpsOne
Built-in_Digital;Camera
Sensor+Type: CMOS sensor
Resolution: 2560 x1920 pixels (4.92MP)
Autofocus-(AF): Supported
Optical_Zoom: 1 x
Macro+Mode: Supported
Built-in;Flash: mobile light (LED)
Camcorder: 640x480 pixels
Recordable-Image-Formats: JPG
Recordable-Video-Formats: 3GP, MPEG4
Power+Supply
Battery:Technology: Lithium-ion battery
Battery-Build: removable
Battery:Capacity: 1230 mAh - Click here for stronger battery
Additional:Details
Built-in:accelerometer: Supported
Additional+Features:
* capacitive touch screen
* WLAN 802.11n mode deactivated
* built-in Digital Compass
* GPRS Class 12
* EDGE Class 12
* HSDPA 7.2
* HSUPA 2.0
* HTC TouchFLO 3D interface v2.5.191
* HTC Sense UI
* Bluetooth stereo audio profile (A2DP
* AVRCP)
* polite ringer
* pre-installed Opera 9.7
* World Card Mobile
* HTC Footprints
* NaviPanel
* Wi-Fi hotspot
* 16GB microSD
Related;Page: http://www.telstra.com.au/shop/Consumer/NGTSOMobilePhonesView?catalogId=10101&..
Datasheet-State: Preliminary specifications
Datasheet;Views: 12320 times
Datasheet-Added: Jan 21, 10 22:56:40
Nếu theo cấu hình thì nó là HD2 thường :D
OK chuẩn men??
