Hip Hop Producer 1.1 iPhone iPod Touch
azerty250776
Now anyone can make professional hip hop music. Even if you’ve never played a musical instrument or written a song before, you can easily create great sounding original hip hop beats with Hip Hop Producer for iPhone and iPod Touch. Choose your favorite beats and melodies from over 100 exclusive samples and assign them to each of 16 beat pads. Configure the beat pads to loop, play once, or play only while you hold them. Then tap away to create your original song.
Hip Hop Producer packs more features than other music-making apps that cost more than twice as much. Here’s what we give you:
- Over 100 exclusive professionally produced samples inspired by today’s chart topping rap, hip hop, and R&B singles.
- CD quality samples (16-bit 44.1kHz)
- All samples are royalty free for your music compositions* meaning you can create your song and it’s yours to sell, give away, play at a party, or do however you please.
- Guaranteed FREE future updates with more great samples.
- 16 interchangeable beat pads that can be assigned to any sample and any function
- Multi-touch enabled. Tap multiple beat pads at the same time.
- 3 types of beat pad functions: loop, one-time play, and hold-to-play.
- Editable volume for each beat pad
- Login to the Facebook Connect portal to let your friends know you’re using Hip Hop Producer for iPhone.
- Full two octave analog synthesizer samples. Load the minisynth samples, change all your beat pads to hold-to-play, and Hip Hop Producer becomes a keyboard.
- Separate Cymbal, Hi-Hat, Snare, Bass Drum, Claps, Congas, and Tom pattern samples provide maximum versatility in creating your beat. Also, change all your beat pads to hold-to-play and Hip Hop Producer becomes a drum kit.
- Your configuration is saved automatically when you close Hip Hop Producer.
dl:
http://rapidshare.com/files/234269370/hproexy.zip
Mirror:
http://www.uploading.com/files/SJJKW7RY/hproexy.zip.html
