(HOT)-@MuscleNerd xác nhận có thể Unlock iPhone với SAM.
HTC_VUTHANH
Tham khaỏ cách unlock iPhone với SAM vừa đc @MuscleNerd đề cập trên Twitter :
I thought the IMSI unlock saga is done and dusted but apparently there are more to it. All credit goes to Loktar_Sun from weiphone.com who pursued an earlier leadthat many, yours truly included, have gave up as a viable exploit.
What do you need: A jailbroken iPhone that can be activated in iTunes (that is, not officially blacklisted), a computer with the latest iTunes installed and working internet connection. You will also need to know the carrier that your iPhone is locked to.
1. Step one: Install Sam Bingner's SAM (Subscriber Artificial Module) package. I recommend that you get it from repo.bingner.com since older versions have a different interface and may not work for this purpose.
2. Enter SAM by either going through the settings menu or find the SAMPrefs icon on your springboard. You will need to have the SIM card you intend to use in your phone.
3. Go to utilities and select "De-Activate iPhone", your ActivationState under "More Information" should now be "Unactivated"
4. With SAM enabled, choose "By Country and Carrier" in "Method"; find your carrier, for some carriers operating more than one Carrier ID you may need to select "SIM ID"; if you pick the wrong one this won't work.
5. Go to More Information", copy or write down the IMSI in "SAM Details", then tap "Spoof Real SIM to SAM".
6. Go back to the main SAM screen and change your "Method" to manual. Paste or enter the IMSI string we saved in Step 5.
7. Connect your iPhone to your computer and allow iTunes to activate it, double click "Phone Number" parameter at the main device screen and make sure that the ICCID matches that of your SIM card. If not you need to start over from Step 1.
8. Unplug your phone, close iTunes.
9. Disable SAM. The source article says to uninstall SAM and delete your lockdownd profiles; it's unnecessary.
10. Connect your phone to iTunes again, you should get an error saying that your phone cannot be activated. This is normal. Just close iTunes and open it again.
11. You should see signal bars in a short time, congratulations.
12. Push notifications may stop working after this procedure but can be easily restored by "clear push" utility in SAM followed by connecting to iTunes.
Your phone will work normally with your SIM card and that SIM card ONLY since we tricked iTunes to accept that ICCID is one of the intended carrier's. The phone can be rebooted and connected to iTunes freely without losing the "unlock", at least for now.
Since it does not involved emergency numbers and test IMSI it will not have any of the issues associated with SIM interposers. Tested working on iOS 5.01 but should work with tethered 5.1 too.
Bài dịch từ bạn nguyenqh(Thanks bạn):
Những gì bạn cần là: 1 cái iPhone có thể kích hoạt được với iTunes (phone không bị blacklisted nhá), 1 cái máy tính kèm iTunes phiên bản mới nhất + internet. Bạn sẽ cần phải biết phone bạn bị khoá bởi nhà mạng nào.
1.: Cài dặt Sam Bingner's Sam. Khuyên: nên cài từ source repo.bingner.com
2: Mở SAM ra, bạn sẽ cần có cái sim mà bạn muốn dùng với cái phone! (sim nhà mạng ấy)
3. Bấm utilities, chọn Deactivate iPhones, bạn sẽ thấy phần "activationstate bên dưới mục "More information sẽ ghi là "Unactivated"
4.Enable SAM, chọn Method là" By country and carrier ", chọn theo thông tin phù hợp với chỗ bạn đang ở!. Một số nhà mạng sẽ cần dùng đến SIM ID, nếu chọn sai thì có thể nó sẽ ko chạy.
5. Mở "more information", lưu lại IMSI trong sam details" bấm spoof real sim to sam"
6. Trở lại màn hình chính của SAM, đổi Method sang Manual. "paste" hoặc gõ dòng IMSI mà bàn đã lưu trước đó (bước 5)
7. Kết nối phone với máy tính, để iTunes kích hoạt, bấm chuột 2 lần vào Phone number ở phần thông tin chính của phone, để ý và kiểm tra rằng số ICCID trùng khớp với cái số của sim bạn. Nếu không, phải làm lại từ đầu.
8. Biết rồi khỏi nói, tháo phone ra, tắt iTunes.
9. Disable SAM. "nguồn viết là nên xoá SAM và xoá cái lockdown profiles, nhưng mà ko cần thiết đâu"
10. Kết nối phone vs iTunes 1 lần nữa, sẽ nhận dc thông báo lỗi rằng phone ko activate dc. Nhưng sẽ ko sao, bình thuơng đấy, đóng iTunes và mở lại 1 lần nữa.
11. Lúc này bạn sẽ tháy sóng hiện lên. Chúc mừng!
12. Phần Push notifications (thông báo cho phone khi có mails, này no..) sẽ ko dùng dc, nhưng có thể fix bằng resotre phần "clear push" ở trong SAM
Phone của bạn sẽ hoạt động bình thường với sim của bạn và chỉ duy nhất cái sim đó thôi do "chúng tôi" đánh lừa iTunes chấp nhận ICCID là của cái sim nhà mạng kia. Phone có thể reboot hay kết nối tới iTUnes thoải mái mà ko sợ mất unlock. (ít nhất kể từ bây giờ)
Hướng dẩn Unlock iPhone(All FW và Baseband) bằng phần mềm SAM.
Hướng dẩn unlock iPhone bằng hình ảnh:
1.: Cài dặt Sam Bingner's Sam. Khuyên: nên cài từ source repo.bingner.com .
3. Bấm utilities, chọn Deactivate iPhones, bạn sẽ thấy phần "activationstate bên dưới mục "More information sẽ ghi là "Unactivated".
5. Mở "more information", lưu lại IMSI trong sam details" bấm spoof real sim to sam".
6. Trở lại màn hình chính của SAM, đổi Method sang Manual. "paste" hoặc gõ dòng IMSI mà bàn đã lưu trước đó (bước 5).
8.tháo phone ra, tắt iTunes.
12. Phần Push notifications (thông báo cho phone khi có mails, này no..) sẽ ko dùng dc, nhưng có thể fix bằng resotre phần "clear push" ở trong SAM.
Video:
[video=youtube;C3Me2ZIPJBE]http://www.youtube.com/watch?v=C3Me2ZIPJBE&feature=player_embedded#![/video]
Chú ý từ bước 1 đến bước 5 nếu có sim nhà mạng Lock các bạn có thể để sim này vào cho tới bước 6 bạn mới lấp sim Việt Nam mà bạn muốn sài,sau đó mới thực hiện bước 6.Trường hợp ở bước 7 kết nối iTunes báo lổi không active được,bạn vào lại Cydia xoá SAM đi,máy sẽ reboot lại =>Kết nối iTunes active là OK(Có thể active đến 2 lần : lần 1 báo lổi,ngắt kết nối sau đó connect lại active =>DONE).
Sau khi làm được rồi các bác nhớ lưu lại toàn bộ file trong /var/Root/library/Lockdown vào máy tính của bạn để nếu Apple có Fix lỗi thì vẫn có cái để active lại,khi cài lại FW chỉ cần copy ngược lại thư mục Lockdown vào máy khởi động lại là có sóng.
Bác nào dùng nhiều sim thì làm nhiều cái Lockdown nhe , 1 sim 1 Lockdown,sim khác thì Lockdown khác nhé
Update 1:
Nếu ai không biết rõ ip lock của mình dùng cho mạng nào thì hãy để SAM làm việc thay bạn, bỏ qua bước 4, vẫn chọn Auto Detect, rồi cắm itune vào để active, mục đích là để SAM tự tìm IMSI phù hợp, sau đó làm tiếp bước 5, quay lại De-active (delete push) sẽ active OK, không cần quan tâm ip dùng sim gốc của mạng nào, nước nào
Update 2
Thanks abinh56789)
Thêm một cách Unlock tương tự nhưng đơn giản hơn:
Bước 1 : Vào Cydia cài Sam->Vào icon Sam -> Utilities ->de-active->revert lockdownd to stock.(nó sẽ báo lỗi succesful là OK)
Bước 2 : Vào method ->chọn by bundle name.Quay trở lại SAm chọn Bundle->chọn nhà mạng máy mình.Trở lại Sam lần nữa chọn SIM ID -> chọn số nào cũng được
Bước 3 : Vào More Infor->Copy dòng IMSI của SAm details ->chọn dòng Spoof Real..-> xong bạn Xóa dòng IMSI của SAm details và paste lại .
Bước 4 : Kết nối với itunes(nếu báo lỗi SIM card ... thì làm lại).còn vào được chỗ active là OK.Tắt Itunes.
Bước 5 : Vào Cydia Xóa SAM.Kết nối với itunes 2 lần .Lần 1 nó báo lỗi(nhưng k sao).Tắt itunes đi,xog mở lại lần nữa.Khi đó chiếc Iphone của bạn đã Được UNLOCK.
Update 3:
Nếu chưa biết rõ máy bạn của nhà mạng nào,bạn có thể check online từ trang web http://sim-unlock.net/iphone_chk/.
Update 4:
Chú ý những ai hay bị lỗi này cách khắc phục.
Rút cáp iPhone ra tắt iTune vào Sam trên iPhone lại Vào phần Method chọn đúng nhà mạng cung cấp iPhone xong cắm iPhone vào mở iTune lên nó sẽ báo kích hoạt ok.
Sau đó vào Cydia Xoá Sam máy reset xong mở iTunes lên lúc này itune nhận iPhone và chờ cho nó reset lần nữa đợi một lúc nó tự kích hoạt và chờ iPhone load sẽ có sóng.
Update 5: (Thanks abinh56789)
Cách Unlock softbank và vezizon (100% thành công):
Bước 1 : Vào Cydia cài SAm->Vào icon Sam -> Utilities ->de-active->revert lockdownd to stock.(nó sẽ báo lỗi succesful là OK).
Bước 2 : Vào method ->chọn by bundle name.Quay trở lại SAm chọn Bundle->chọn nhà mạng máy mình.Trở lại Sam lần nữa chọn SIM ID -> chọn số nào cũng được.
Bước 3 : Vào More Infor->chọn dòng Spoof Real..-> xong bạn Xóa dòng IMSI của SAm details và paste số này vào(Softbank thì 440208111139147 . VeziZon thì 204043370402260).
Nguồn:H.I.P
hungphilong
Đã test trên con 4 thường fw 5.0.1 bb 04.11.08 dùng sim mobi sóng cấp 10 mạng 3G lướt vèo vèo :D
Taki7610
Unlock_GSM
Đã test ok 2 con, chỉ có điều mấy con FW cũ như 4.1 hay 4.3.3 thì hơi mệt, gởi IME cho AT&T là thơm nhất :D
Taki7610
Unlock_GSM
THE END of Unlock iPhone 4S, iPhone 4, iPhone 3GS Using SAM [5.0, 5.0.1, 5.1]
Apple khóa unlock iphone bằng Sam
MuscleNerd ‏
MuscleNerd ‏
Looks like Apple's currently fixing their activation servers. But the good news is that previous tickets gotten via SAM trick still work.
[U]Quote:[/U]
We need to confirm from Sam Bingner on Twitter,but really i have tried in 4 iPhone 4 from at&t but no success,hope to not be closed.
Quote:
i have tried in 3 iPhone 4 AT&T and always says
Activation reports Error:
ActivationInfo rejected. You mus select orginial carrier SIMID of your phone
