friendship19
Windows 3.1 on Symbian - Installation Guide!
DOWNLOAD DOXBox v0.72 for Symbian:
http://www.mediafire.com/?iyiamvwufmw
DOWNLOAD Windows 3.1 for Symbian:
http://www.mediafire.com/?hw5ozxtvljw
INSTALLATION GUIDE v1.0
I. DOSBox v0.72 for Symbian
1. Unpack 'DOSBox_s60v3_(Marcin-prv).rar' archiwe to your Memory Card
2. Install ALL aplication from 'Install' directory.
3. Try install DOSBox_Full.sisx
4. If show message: 'Not enought memory' install 'DOSBox_Slim.sisx' and replace previous version.
II. Windows 3.1 for Symbian (included Norton Commander 5)
1. Unpack 'Win3.1-on-s60v3_v1.0_(Marcin-prv).rar' archive to your Memory Card.
2. Run DOSBox.
III. To switch between Windows 3.1 and Norton Commander 5.
1. Go to 'Data' directory on your Memory Card and find 'dosbox.conf' file.
2. Edit file in notepad.
2.1 To run Windows 3.1
# Loader 1 -- Windows 3.1
# mount a e:\Data\win31\ (To install more drivers)*
mount c e:\Data\
mount d e:\
c:
c:\Windows\win.com
# Loader 2 -- Norton Commander 5.0
# mount c e:\Data\
# mount d e:\
# c:
# c:\nc\nc.exe
* TO install new drivers you need tu put Windows 3.1 installer files to e:\Data\win31 directory.
Edit 'dosbox.conf' file and remove '#' in 'mount a e:\Data\win31\' line.
2.2 Run Norton Commander 5
# mount c e:\Data\
# mount d e:\
# c:
# c:\Windows\win.com
mount c e:\Data\
mount d e:\
c:
c:\nc\nc.exe
IV. Suggestions
1. To switch between the mouse and the keyboard press "Call" key.
2. Turn off automatic screen rotation, it may cause DOSBox close.
3. To change DOSBox allocated 2MB RAM edit line 'memsize=2' in file 'e:\Data\dosbox.conf'.
Screenshot from first installation:
Đã Test trên N95!
2. Run DOSBox.
mount c e:\Data\
mount d e:\
c:
c:\Windows\win.com
# mount c e:\Data\
# mount d e:\
# c:
# c:\nc\nc.exe
# mount c e:\Data\
# mount d e:\
# c:
mount c e:\Data\
mount d e:\
c:
c:\nc\nc.exe
IV. Suggestions
Đã Test trên N95!
