How To Update Samsung S5750E / S5753E Wave575 Firmware !
Taki7610
Unlock_GSM
- MultiLoader_V5.56 - S5750EXXKC2_OXAKB1.rar | 138.3 MB
[I][B]*** Run Samsung S5750E Wave575 downloader and select BRCM2153
- In case you want to flash Boot files you have to check Full Download option.
- For this Guide we select this Firmware as example: S5750EXXKC2-OXAKB1 to show you what files to select.
- Extract the Firmware package to check what files you have inside it.
- Click Boot and select: BOOTFILES folder ( complete folder not the files inside it )
- Click Amss and select: amss.bin
- Click Apps and select: apps_compressed.bin
- Click Rsrc1 and select: Rsrc_S5750E_Open_Europe_Common.rc1
- Click Rsrc2 and select: Rsrc2_S5750E(Low).rc2
- Click Factory FS and select: FactoryFs_S5750E_Open_Europe_Common.ffs
- Click CSC and select: CSC_S5750E_Open_Europe_Common_OXA.csc
- Click SHP APP and select: ShpApp.app
- Click FOTA and select: bplib_S5750EOpEuroCommon.fota
- Put the phone into Download Mode: Volume Up + Camera + Power.
- Connect USB cable to Phone and PC and install drivers if asked to.
- Click Port Search to check good connection.
- Click Download to start the update process and wait till the phone restart.
- After the phone restart do full reset by this code *2767*3855#[/B][/I]
