HP iPAQ h6365 / h6345 / h6340 / h6325 / h6320/ h6315 / h6310
rizal
hp iPAQ h6365 / h6345 / h6340 / h6325 / h6320/ h6315 / h6310 Hard Reset Without Removing Battery:
Press hold down power button then press hold down the reset button. Please do not release it till appear bootscreen. Once this is completed successfully you are has already format your hp iPAQ h6365.
hp iPAQ h6365 / h6345 / h6340 / h6325 / h6320/ h6315 / h6310 Bootloader Mode:
Keep press hold down buttons 1 and 2 (contacts and email) and then press the reset button on the left side. Release the reset button without releasing buttons 1 and 2. Once this is completed successfully you are has already into bootloader mode, then you will see BL in the lower right hand corner. Now you can release buttons 1 and 2 to keep continue it.
hp iPAQ h6365 / h6345 / h6340 / h6325 / h6320/ h6315 / h6310 Drivers, Software & Official Latest ROM
hp iPAQ h6365 / h6325 / h6320/ h6315 / h6310 Specification Details
hp iPAQ h6345 / h6340 Specification Details
Regards,
hp iPAQ h6365 Advance User b-)
rizal
Still need WM2003 SE for hp iPAQ h6365, wondering someone will make it someday soon ...
rizal
Still waiting just WM2003SE only for hp iPAQ h6365! Is there anyone can do WM2003 SE ROM upgrading for hp iPAQ h6365? Please help me!!!
