HP iPAQ HX2000 Series WM6.5 - 5.2.23007 WWE - WM6.5.SPv3 by Spiaatie
sangbsdk
This Update is only for HP iPAQ HX2000 Series iPAQ's:
HX2100 series: HX2110 - HX2115 - HX2190 - HX2190b - HX2195 - HX2195b
HX2400 series: HX2410 - HX2415 - HX2490 - HX2490b - HX2495 - HX2495b
HX2700 series: HX2750 - HX2755 - HX2790 - HX2790b - HX2795 - HX2795b
Carefully read all first 3 posts!!!
DON'T TRY TO UPDATE iPAQ's ending with C as it DOES NOT WORK!
ROM Update Works with Windows - 2000 / XP / Vista / 7 x86 (32bit)
HOW TO UPDATE ROM? Just read README file INSIDE UPDATE FOLDER!
After update make a hard reset: Calendar + Messaging + Power + Reset with stylus
Download links are in attached TXT file.
Screenshots
Donations are welcome!
USD / EUR / GBP
If You would like to see updates in future - support me.
* Special Thanks to «R_User (NeverGone)» for Start Menu Icon Fixes and new iPAQ Wireless design.
Please don't mirror my files anywere else!!!
Nguồn từ forum.xda-developers.com
* Mọi người tải link phía dưới nhé. Đã test thử, hiệu quả rất tốt.
sangbsdk
Đã có WM6.5.SPv4 by Spiaatie
Mọi người cùng nhau test sử dụng nhé.
phuna
bác sang ơi bản này cài tiếng Việt kiểu gì, em úp rom chạy ngon rồi nhưng duyệt web tiếng Việt bị lỗi chữ
sangbsdk
[ROM] [iPAQ hx2000] [WM6.5] Tomahawk ROM Series by Spiaatie
Description:
- Carefully read all first 3 posts!
- ROM Update Works with Windows - 2000 / XP / Vista / 7
- How to update ROM? Just read README file inside update folder!
- After update make a hard reset!
- Please don't mirror my files anywere else!
- hx2110(5) and hx2410(5) users MUST update ROM in following sequence:
* 1.00.00L -> 1.00.00H -> 1.02.00H -> WM 6.x
Current Release:
- WM6.5.SPv7C ENG - Tomahawk v7 Classic - CE OS 5.2.21903 (Build 21903.5.0.92)
- WM6.5.SPv7T ENG - Tomahawk v7 Touch - CE OS 5.2.23569 (Build 23569.5.5.0)
THIS ROM WORKS ONLY WITH:
hx2100 series: hx2110 - hx2115 - hx2190 - hx2190b - hx2195 - hx2195b
hx2400 series: hx2410 - hx2415 - hx2490 - hx2490b - hx2495 - hx2495b
hx2700 series: hx2750 - hx2755 - hx2790 - hx2790b - hx2795 - hx2790b
NEVER TRY TO UPDATE hx2490c OR hx2790c - You will brick it!
