Hướng dẫn cách làm Big Storage cho WIZA !!!
hongkong
Đây là hướng dẫn làm big storage của dòng Hermes!
Bác nào rành tiếng anh và hiểu về nó dịch lại giúp !
Bác nào đã làm được trên các dòng khác ra tay giúp đỡ đi. Em mò mãi mà không ra cái này !!!!!!
Tham khảo thêm ở đây: http://forum.xda-developers.com/showthread.php?t=360461
Nguyên văn
This HoTo is based in Bepe metode and explanations from cicciocant
Cicciocant don't have a Thread abaut this in the forum, but have a similar explanations in Italian, in a Italian Forum.
Bepe Thread.
http://forum.xda-developers.com/showthread.php?p=1476021#post1476021
Post from Cicciocant in the Italian Forum.
http://www.a1kstyle.com/viewtopic.php?p=121913#121913
and 1 mor time sorry for my bad ENG.[/size][/B]
First you need a Base Rom.
Tools at end of this Post
With the nbhtool from dutty's decompile the RUU_signed.nbh
Now you have some new *.nb files
rename Windows.nb to OS.nb
So we start from the ROM format os.nb
with the tadzio tools and Bepe package tool Extrat SYS e OEM.
Put SYS and OEM in your Kitchen, Create a ROM folder in the Kitchen leave blank for now. (There goes the xip that we must first patch)
Now take the file OS.nb
Export xip.bin with the commands:
nbsplit -hermes os.nb
rename OS.nb.payload nk.nb
RomMaster -w 5 nk.nb -x -o xip.bin >NUL​
Now you need xipport from Bepe include
Execute Xipport in the same folder where you have nk.nb and xip.bin
Press [dump xip.bin] and you create a folder OUT dont close the XIPPORT
0000y7b2
Go inside OUT\MODULES\ FLASHDRV.DLL and open the file s000 with a HEX editor.
FLASHDRV.DLL S000 needs of these changes:
- "58 20 43" to "04 20 43" (1 time)
- "58 30 43" to "04 30 43" (3 times)​
These values them are exactly the times that says Bepe, then you can not go wrong.
A this point go to XIPPORT again
First Push [realloc P] and then [Build xip_out.bin]
0000zg6e
You now have the xip patched and you must merged with nk.nb.
At the bottom of XIPPORT there are two lines
In the last one we write nk.nb (there should be already written)
In the first one will be written the address within nk.nb begins where the xip.bin
How do you know the address?
Open the xip.bin with Hex editor and you see that begins with
FE 03 00 EA 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
45 43 45 43 68 1B 19 80 68 1B 19
Now open nk.nb with a hex editor and you trying find the address that begins with the hex sequence.
What is the data that you must enter in the first row on xipport?
You go see that address that begins with the hex sequence at 00000400 is not that one, and another at 00320000 or someting like that, this is the correct one.
In my Hermes is 00320000
See the image in Post: http://forum.xda-developers.com/showpost.php?p=1837256&postcount=22
A this point press the [xip_out.bin write to:]
000106e6
And now you have the nk.nb with the xip patched.
Now you need re-create the os.nb file with the commands:
rename nk.nb os.nb.payload
NBMerge -hermes os.nb​
A this point you need edite the OS.nb in the Hex editor
- BN files: 0x000001F5: short value + 0x48 (eg: 0xA7 +0 x48 = 0xEF)
- BN files: 0x000001FB: short value + 0x48​
This Hex Egitor is in attach Files
Attention. Let me give you an example of how I have done:
0x000001F5: A7 00 + 0x48 = EF 00
0x000001FB: A5 01 + 0x48 = ED 01​
Now copy the OS.nb and puts it inside the folder ROM in your kitchen.
Since then, we extract the xip from the OS.nb with the commands:
del os.nb
del OS.nb.extra
rename OS.nb.payload nk.nba
RomMaster -w 5 nk.nba -x -o xip2.bin >NUL
mkdir XIP
dumprom xip2.bin -5 -d XIP >NUL​
Last Steep:
Remove IMGFS\OEM\OEMDrivers\OEM_FLASHDRV.DLL
Delete all references "ExtRom" in:
XIP: boot.rgu, boot.hv;
IMGFS: default.hv;​
Using the regcomp and the notepad to delete/edit the HV files, you need [size=+1]SAVE AS the RGU file, and select the type as "Unicode" The reason to Save as Unicode, is because rgucomp can only read Unicode
Dont forget to put in the first line REGDIT4 and a Blank line afther that, and also a Blank lile at end of the file.
Then you can convert again the RGU file to HV file with the regcomp[/size]
Regards to all cooker's
Lamson
Mình cũng có nghiên cứu cái này mấy tuần trước, nhưng của Prophet ( chắc cũng giống Wizard không) nhưng không thấy có module này FLASHDRV.DLL trong thư mục Out của Prophet, nên cũng chưa biết làm sao
hongkong
Đúng rồi tìm cái này FLASHDRV.DLL lòi cả mắt mà không thấy, không biết với WIZA và Prophet thì nó là module nào nữa.
Còn thêm cái vụ Splash Screen động nữa (HTC logo > Splash Screen > Animation > Welcome) cái này Animation làm mãi vẫn không được
Mong các chuyên gia ra tay (man, smod, pro HTC, pro trans .... ) ra tay giúp đỡ !!!!!!!!!!!!
hector
hic mong sao có sớm cái minis của em jo dùng không có thẻ chăng khác j 1100i thêm M nào hay M nấy!
thekhoa202302
các pro ơi giúp dùm vụ này với!!! thấy nó hay wá mà không làm gì được...Thanks
