Taki7610
Unlock_GSM
Mình hướng dẫn các bạn cách up ROM cho dòng HP iPAQ 210/214 Enterprise Handheld , đây cũng là cách giúp cho anh em nào có máy xài các thứ tiếng khác muốn trở lại bản tiếng ENGLISH hay muốn con HP_IPAQ mình có bản ROM mới khác !
Cách up mình xin để nguyên bản gốc - Như vậy sẽ tốt hơn ! Xin chân thành cảm ơn Elektrownik - Globalbus
Mình đã chuyển thành công 1 con từ ROM G E R sang ROM E nên anh em cứ làm theo đúng trình tự là ok !
Goodluck!
Download:
bldiag.nb0
ROM :
Orginal chinese ROM
ROMs (by Globalbus):
Win 6.1 : 6.1 v2 like first 6.1 release, but much cleaner
6.1 clean, with a lot of free space
Win 6.0 : : 6.0 with lot of free space
Win 6.5 : : 6.5 clean by dxdy (today and menu like in standard 6.5)
[B][U]General informations:[/U][/B]
IT IS IMPOSSIBLE TO BRICK DEVICE, YOU CAN ONLY BRICK WHEN YOU RESTORING LINUX BACKUP, ROM UPDATE DOESNT AFECT OBMS (OEM BOOT MODULES) AND FIRST BOOTLOADER
[B][U]File names:[/U][/B]
FILES MUST BE: HPIMAGE.BIN (UPDATE IMAGE) AND BLDIAG.NB0 (UPDATE LOADER)
[U][B]SD Card:[/B][/U]
SD CARD CANT BE BIGGER THAN 2GB, BUT THERE IS NO GUARANTY THAT YOUR SD CARD WILL WORK, OBMS ARE LOW LEVEL CODE, SO THEY CAN NOT RECOGNIZE SOME CARDS
SD CARD MUST BE FORMATED WITH FAT-16 FILE SYSTEM, OBMS DOESNT SUPPORT ANY OTHER
HPIMAGE.BIN AND BLDIAG.NB0 MUST BE ON ROOT OF SD CARD
[U][B]Rom update:[/B][/U]
TO UPDATE ROM COPY HPIMAGE.BIN AND BLDIAG.NB0 TO SD CARD, PRESS CALENDAR AND WINDOWS KEYS AND THEN RESET DEVICE, IT DOESNT MAKE DIFFERENCE HOW YOU DO THIS, YOU CAN PRESS RESET BUTON OR SOFT RESET FROM ANY APPLICATION WHICH SUPPORT THIS
[B][U]P:/s :[/U][/B] IF NOT DEVICE WILL REBOOT TO WINDOWS (THIS MEAN THAT THERE IS PROBLEM WITH SD CARD AND BOOTLOADER DOESNT SEE IT OR YOU RELEASE BOOTKEYS TOO FAST)
IF YOU WILL SEE WHITE SCREEN AND "NO IMAGE FOUND" THIS MEAN THAT:
-SD CARD IS BAD AND BOOTLOADER DOESNT SEE HPIMAGE.BIN
-UPDATE IMAGE NAME IS WRONG, IT MUST BE HPIMAGE.BIN
-UPDATE IMAGE IS DAMAGED
AFTER UPDATE IS FINISHED DEVICE WILL REBOOT IN CLEAN BOOT MODE
IF IT WILL NOT START WINDOWS AFTER THIS BUT WILL STAY IN THIS MODE IT MEAN THAT:
-UPDATE WAS NOT COMPLEATED
-UPDATE IMAGE WAS DAMAGED
Goodluck!
Download:
bldiag.nb0
ROM :
Orginal chinese ROM
