Hướng dẫn Jailbreak firmware 2.1 bằng QuickPWN
Gozilla85
Sáng sớm "đi dạo" web 1 vòng thấy có cách Jailbreak cho FW 2.1, post lên cho anh em "ngâm cứu". Mình cũng đang làm thử đây :))
just now sleepers.net has updated its site
now the following method works for both 3G and 2G phones
2.1 2g and 3g Jailbreak
Author: BigBoss // Category: jailbreak
This is not the easiest guide, but it is for expert users and early adopters that have a 3g and Windows. The guide is courtesy of Geeb. This guide is for contract carrier subscribers only. If you are unlocking your 2g, wait for another method.
Warning: at this point, no 3rd party apps show up after install. Will update this as soon as we have a solution.
Step 1) Download the 2.1 3g firmware or 2g firmware.
Step 2) Install itunes v8 - you can get all versions of iTunes here.
Step 3) Update the iphone with iTunes and make sure it is activated!
Step 4) Download quickpwn with the correct 2.1 bundle inside it here.
Step 5) Run quickpwn…select your iPhone1,2_2.1_5F136_Restore.ipsw or iPhone1,1_2.1_5F136_Restore.ipsw from step 1.
Step 6) You can select cydia and installer and logos if you wish (make sure you select Cydia).
Step 7)When it is finished the phone will reboot…Cydia and Installer will NOT be visible
Step 8) Download TotalCommander and t-pot addon
Step 9) Install TotalCommander and in the left pane navigate to T-PoT.1.1.zip and click on it. It will install t-pot automatically.
Step 10) Download the mobileinstallation patch
Step 11) Use Totalcommander to install patched mobileinstallation to /System/Library/PrivateFrameWorks/MobileInstallation.framework … clickon the dropdown box [-\-] top left and select network neighborhood then t-pot. Reme,ber to back up your original mobileinstallation first!
Step 12) Still in TotalCommander delete /private/var/mobile/Library/Caches/com.apple.mobile.installation.plist
Step 13) Reboot the phone and all is good!
Step 14)
Download quickpwn-gui-for-2.1.rar - (first file) mirror
Download quickpwn-2.1-2g-3g.rar - Updated file - mirror
jumong
Sáng sớm "đi dạo" web 1 vòng thấy có cách unlock cho FW 2.1, post lên cho anh em "ngâm cứu". Mình cũng đang làm thử đây :))
Tôi nghĩ là nên đổi lại : cách Jailbreak giống như chủ đề topic bạn đã giới thiệu.
Bởi vì : "If you are unlocking your 2g, wait for another method" ==> Nếu bạn muốn unlock iphone 2G của bạn thì hãy chờ phương pháp khác.
(Đã edit lại nội dung topic, cám ơn bạn đã góp ý :D)
AnhTu
XuanTruong
Nói chung cách này vẫn hơi "Nhiêu khê" các Bạn ạ!:)) Chờ cách Jailbreak đơn giản hơn!:)
XuanTruong
Đã update xong bản FW 2.1 hồi 3h sáng, đang test tiếp :D
Ạc! Dạo này rảnh rỗi gớm nhỉ?:)) Có gì mới thông báo nhé, nghe thông tin thấy cũng không có nhiều thay đổi nên từ từ cái đã!:)
AnhTu
Theo ý kiến riêng của mình, cần phải làm các bước sau để có 1 FW thật hoàn chỉnh & sạch sẽ nhé, các bước như sau:
- Nếu đang ở 1.1.4 hay 2.0.x thì các bạn hãy restore lại FW cũ thêm 1 lần nữa ( giống như đưa máy về tình trạng xuất xưởng, máy sẽ chưa có bất kỳ phần mềm nào cài lên). Nếu các bạn restore FW Custom thì sẽ không được như ý vì các CT FW có cài đặt sẵn các soft, khi update sẽ vô tác dụng, ngay cả việc resize Storage cũng sẽ ảnh hưởng và khi update xong iP cũng sẽ nhận storage như cũ, nên restore bản gốc và jailbreak xong rồi tiến hành update.
- Sau khi đã restore, máy sẽ vào SpringBoard và như bình thường, đây là lúc chúng ta bắt đầu upgrade FW, sẽ có các bước sau:
a. Khi upgrade FW, chọn Update (đây là lý do tại sao các bạn được yêu cầu phải restore lại cho sạch sẽ, vì khi update sẽ không giống như Restore, tức là máy chỉ update FW mà thôi chứ không xóa tất cả những gì có trong máy, mình phát hiện ra điều này khi cài soft, trong Installer & Cydia vẫn phát hiện các soft cũ đã install, nhưng thực tế thì lại không thấy ở ngoài Springboard).
b. Sau khi update xong, hãy làm tiếp tục các bước như hướng dẫn ở trên.
Uki! Chọn Update xong rồi Jailbreak nhé, chứ chọn Restore là tiêu đấy!
Khi chạy QuickPWN, máy sẽ tự động jailbreak & tự vào Springboard đấy anh ạ :D Vào xong vẫn gọi & nhắn tin như bình thường.
Haiz, thức đến 4h sáng xong update luôn FW mới, đến giờ mới phát hiện những lỗi này nên mới post muộn thế :D
Gozilla85
He he, theo em thì làm thế này:
1/ Restore FW gốc 2.x.x
2/ Dùng QuickpwnR3 jailbreak lại
3/ Connect iP va Itunes 8.0, bấm SHIFT + UPDATE FW gốc 2.1
4/ Không cần uninstall Itunes 8.0, dùng Quickpwn 1.2.0 jailbreak FW 2.1. theo các bước trên
