anhchanbonmat
Phần mềm quản lý quá pro quá quen thuộc đây
Đây là ứng dụng bên s60v3 vì mình không có máy s60v5 để test nhờ các bạn giúp
Và đây là
Jbak TaskMan v1.37 EN
Jbak TaskMan v1.37 S60v5 VH SymPViet
![Screenshot0031-2.jpg](http://i832.photobucket.com/albums/zz244/anhchanbonmat/Screenshot0031-2.jpg)
![Screenshot0032-3.jpg](http://i832.photobucket.com/albums/zz244/anhchanbonmat/Screenshot0032-3.jpg)
![Screenshot0033-3.jpg](http://i832.photobucket.com/albums/zz244/anhchanbonmat/Screenshot0033-3.jpg)
What's new:
● [add] Tactile feedback for touchscreen smartphones.
● [add] If for selected task set the rule or set to highlight - this is displayed on the info panel.
● [add] In the tasks list available backlight control.
● [add] Flashlight uses a camera flash. Doesn't work on all models.
● [fix] Nokia N97 - in some settings, short press on the Menu to triggered the main window and the system tasks list.
● [fix] Option "Kill after send to back" worked not properly.
● [fix] When opening the main window, cursor in the fast start was not raised on top element.
● [change] Accelerated icons boot.
● [change] For phones with 240x320 screen resolution in grid quick launch can be add more elements.
● [change] On touchscreen phones elements are focused by pressing.
Và đây là
![herevk1.gif](http://i832.photobucket.com/albums/zz244/anhchanbonmat/herevk1.gif)
![download_F1R.gif](http://i832.photobucket.com/albums/zz244/anhchanbonmat/download_F1R.gif)
