anhchanbonmat
Phần mềm quản lý quá pro quá quen thuộc đây
Jbak TaskMan v1.37 S60v3 VH SymPViet
What's new:
● [add] Tactile feedback for touchscreen smartphones.
● [add] If for selected task set the rule or set to highlight - this is displayed on the info panel.
● [add] In the tasks list available backlight control.
● [add] Flashlight uses a camera flash. Doesn't work on all models.
● [fix] Nokia N97 - in some settings, short press on the Menu to triggered the main window and the system tasks list.
● [fix] Option "Kill after send to back" worked not properly.
● [fix] When opening the main window, cursor in the fast start was not raised on top element.
● [change] Accelerated icons boot.
● [change] For phones with 240x320 screen resolution in grid quick launch can be add more elements.
● [change] On touchscreen phones elements are focused by pressing.
