This is my Third ROM after "HTC Atom WM6 Premium", and i gave my third ROM name "Kumara WM6 Premium",.
What makes me built it??
- It have new (OS CE 5.2.2000 Build 20000.1.0.0)
so, this ROM is for XDA ATOM or XDA ATOM PURE ONLY,.
Just like the first and second ROM, this is a clean ROM too, added:
- WM5Torage v1.78
- HTC Task Manager v2.0
- Adobe Reader LE
- Xn Viewer
- 1-Calc
- Soft Reset
- Oxios Close Apps v1.40
- NetCF v3.5
- A2DP works with my Nokia HS-4w
- Battery drain improvements, (proven with my GPS usage that improve to 4,5 Hours usage with bluetooth connectivity)
- SPB PocketPlus 4 smart scrolling compatible
The most Interesting things here are:
+ Most programs and settings icon changed
+ New sound scheme, (please please please, check it out, my atom speaker is broken, so i cant hear it very clearly)
Here is the upgrade procedure,.
1. Enter BootLoader menu (by pressing "Action button + Reset button")
2. Connect XDA ATOM to PC using USB cable
3. Run "Update.exe" (located in "Kumara WM6 Premium" folder)
4. Perform Hard Reset when it finished
link download:
http://www.mediafire.com/?2jzoxw9ojmb
http://rapidshare.com/files/82058907/kumara__OS_5.2.2000_Build_20000.1.0.0__-_WM6_Premium.zip
đã test bản rom này 1 ngày nói chung khá ổn, tốc độ khá tốt, chưa thấy đụng soft, giao diện đẹp, các icon theo phong cách vista, chưa test được wifi, nói chung cũng đáng để các bạn up thử rom này
hình ảnh chi tiết xem thêm tại đây: http://forum.xda-developers.com/showthread.php?t=357106
- WM5Torage v1.78
- Adobe Reader LE
- Xn Viewer
- 1-Calc
- Soft Reset
- NetCF v3.5
link download:
